4l80e swap and need flex plate bolts
Old 12-05-2014, 01:50 PM
SumtinCoo's Avatar
Default 4l80e swap and need flex plate bolts
I'm doing a 80e swap in my 01 sierra truck from a t56 its already got a 05 iron block 370 and I'm going to be using a Hughes flex plate and the spacer and a 6 bolt converter. I want to use arp bolts but seems like the only ones I've been able to find are the $60 circle d ones. I found arp PN 244-2902 and it says "GM LS Series with adapter plate Flexplate Bolt Kit" they look longer but I can't seem to find a length on them anywhere. Anyone use these and know if they'll be the right ones?
Thanks
Old 12-05-2014, 03:12 PM
Circle-D's Avatar
A few questions for you...just to confirm you have the short LS crank? And 4004X Hughes Flexplate? 6 bolt converter, do you now what bolt pattern is on it?
Chris
Old 12-05-2014, 03:19 PM
SumtinCoo's Avatar
Chris
I haven't gotten a converter or flex plate yet but I plan on buying the Hughes HP4004X-EBP flex plate and a billet converter to match it. Should just be the standard 4l80 6 bolt converter pattern. And yes short snout crank.
Old 12-06-2014, 05:32 PM
Circle-D's Avatar
We offer a 6 bolt converter that will have the longer LS pilot so you would not need the spacer. And with the dished flexplate, you will run the spacer on the converter side of the flexplate, not using it like GM did. So it depends on what converter you plan to get to know if you need the spacer and that will determine the crank bolts you need.
Chris
Old 12-06-2014, 05:40 PM
SumtinCoo's Avatar
Chris
Okay thanks. I'll send you a ask Chris form and see what you recommend.
Old 12-06-2014, 05:42 PM
Circle-D's Avatar
This is what we call a "Dual LS" has both 4L80 and LS bolt patterns on a 6 lug setup with the longer LS pilot. We have it in a single or multi disk option in a 245mm, 258mm or 265mm configuration depending on your setup. This will fit just about every flexplate combo out there.
Chris
Old 12-06-2014, 05:43 PM
Circle-D's Avatar
Sounds good, thanks.
Chris
Old 12-06-2014, 06:16 PM
SumtinCoo's Avatar
Just sent the forum. Thanks
Old 12-07-2014, 07:34 PM
Circle-D's Avatar
I apologize for the slow response... We changed email servers this weekend. I think it will be back up and you will get a response tomorrow.
Chris
Old 12-07-2014, 11:34 PM
SumtinCoo's Avatar
No problem. I won't have the money till after christmas anyways. Just trying to get all my ducks in a row on this swap.
Old 12-10-2014, 04:27 PM
SumtinCoo's Avatar
Just wondering if you had time to look at that ask chris. I haven't gotten a reply yet. If you sent one I didn't receive an email. I understand that you're busy so no rush. Thanks
Old 12-10-2014, 04:47 PM
Circle-D's Avatar
I guess we missed it....All emails are currently answered. I will do some digging and see if I can find it.
Chris
Old 12-10-2014, 04:57 PM
SumtinCoo's Avatar
Okay thanks. If you need me to send another just let me know.
Old 12-10-2014, 05:05 PM
Circle-D's Avatar
Found it....forgot to move it over to our new server - Sorry.
Sent a reply.
Chris
Old 12-10-2014, 06:13 PM
SumtinCoo's Avatar
Got it and I replied to it. Thanks
Quick Reply: 4l80e swap and need flex plate bolts
