help ASAP: Tranny lines; reverse thread or not?
Im in the middle of the TC change and cannot get the hard tranny lines to turn. I HAVE removed the wire e-clips and they won;t budge. Also what size are they, i have tried 18,19 mm and 11/16 and 3/4 and its either not going on or too loose. Cresent as of now!
wait, so they just pull out once the e-clips are removed? Every other tranny have needed to use a wrench. The write up is not that specific, it just says they should come out easy now. FYI: this is the write-up i have been using to do the install.
I just did my converter install last week so I know for sure. you just pull back the bushing and then remove the e-clip once the clip is out just pull on the line and it will come right off.
