Need to get 4L60E temp down below 200 degrees *Help*
I have a FI car and in no time driving around town the tranny temps can get to 235 degrees easy with no spirited driving, just in stop and go traffic.
I have heard deep pans and trans coolers for these transmissions help lower temps. Does anyone have proper part numbers of what exactly I need to get these temps down. Thanks.
Good advice. I recently installed a deep pan and actually it does seem to be working (I was on the fence about whether I thought it would help). Bypass the stock cooler, external cooler, deep pan and it will be worlds different.
Take the lines that run into the radiator off, and run them to a LARGE trans cooler. Plug the radiator. The radiator only heats up the trans fluid in cold conditions, and over heats it in 70-90 degree days. Get a large cooler, or better yet one with an electric fan and connect it to the lines.
I am thinking about going with this one.
http://www.makcotransmissionparts.com/4739-1.html
How do I hook it up? I want to bypass the radiator
I listed out what you needed via PM.
Get sweet performance AN trans fittings (-6 or -8), 2 fittings to connect to the trans in/out, 20ft of AN hose (feed and return) , a trans cooler, 2 more fittings to connect the hose to the trans cooler and mount it where there is good airflow.
