Old 04-25-2016, 05:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Tranmission Guides
Print Wikipost
4l60 wont shift out of first
Old 09-02-2015, 02:10 PM
LsXRs's Avatar
Default 4l60 wont shift out of first
I have a issue with my transmission it won't shift out of first. I tried doing research but everyone issues end up being the vss. But mine is working properly I even tried manually shifting the transmission out of first and still wont get out of it. Any pointers on what it could be or is transmission toast?
Old 09-02-2015, 03:09 PM
coryforsenate's Avatar
Do you have a line pressure gauge you could hook up? And a scanner to see if there's any codes.
Old 09-02-2015, 04:09 PM
LsXRs's Avatar
I dont have a gauge but I can get one. As for codes yes I do.
Old 09-02-2015, 04:10 PM
LsXRs's Avatar
These. Are the codes I get p0740 p1336 p1810 p1860
Old 09-02-2015, 11:57 PM
LsXRs's Avatar
So today I decided to test the tps. I got 1.8v at idle and 4.5@ wot I know the idle is wrong but wot seems about right from my research could tps be bad?
Old 09-03-2015, 08:05 AM
bbond105's Avatar
After doing a simple search on the codes that you posted. It seems that you have some electrical problems with your pressure manifold switch and TCC PWM solenoid. I know from experience that a defective pressure manifold switch will make a trans do some stupid things.
Old 09-03-2015, 11:33 AM
New AC Delco solenoid and pressure switch together are about $50.
Old 09-03-2015, 03:18 PM
LsXRs's Avatar
Which solenoid?
Old 09-03-2015, 04:09 PM
This guy.
Old 09-03-2015, 06:29 PM
LsXRs's Avatar
Could that be causing my no shift?
Old 09-03-2015, 06:51 PM
That solenoid controls torque converter engagement.
As bbond105 said, the manifold pressure switch is probably causing the shifting problem.
Old 09-03-2015, 08:04 PM
clinebarger's Avatar
Check your harness over real good, Maybe it got on the exhaust or something.
P0740 is for the TCC Enable solenoid (Part of the harness)
P1810 is for the Pressure switch manifold.
P1860 is for the TCC PWM solenoid.
I rarely see PSM's go bad, Maybe 1 every couple years, It very well may be bad, But a shorted wire will set P1810 also.
Same goes with the other 2 codes (Shorted or Open wires).
Good Luck! Having 3 electrical components bite the dust is not likely....But possible, I hate to see people blindly throw parts at problems, All it does is make your wallet lighter.
Old 09-04-2015, 02:28 AM
LsXRs's Avatar
Will have a good look at harness tomorrow hopefully it is. Ill update see if I find anything bad or unusual.
Old 09-04-2015, 06:18 AM
bbond105's Avatar
I did not mean to imply that the solenoid and manifold pressure switch were the problem but that the problem was in those electrical circuits.
Old 09-04-2015, 07:01 PM
I didn't mean to come off as dick, I wasn't aiming my post at you or anyone else that posted, I just wanted the OP to visually inspect the harness thoroughly before going further.
Old 09-04-2015, 07:41 PM
bbond105's Avatar
It’s all good man; I didn’t take it that way. I was in a hurry and should have been more specific in about what I was saying. You make a very good point about the harness. I agree so many go off halfcocked and waste a lot of money. It’s nice to have someone else as knowledgeable as you on here answering questions.
Old 09-07-2015, 12:44 PM
LsXRs's Avatar
Well I checked all the wiring its good no damages of any sort.
Old 09-07-2015, 07:58 PM
Your going to have to do some diagnostics, Lets start with the P0740 & P1860 (TCC Enable & TCC PWM solenoid).....I'm GUESSING this is a gen 3 engine & harness?
Unhook battery, Disconnect both PCM connectors, Reconnect battery.
Key on, Probe pin 42 of the Blue PCM Connector with a Test light that is hooked to ground, The test light should light up.
Next, Take a fused jumper wire & Apply ground to pin 42, You will here a click if the solenoid is good, (Don't be surprised if it only clicks once, Some TCC Enable solenoids don't release without fluid pressure acting on them) This tests the TCC enable circuit per P0740.
Key on, Probe pin 2 of the Blue PCM Connector (Bla,bla, Same as above), Though TCC PWM solenoid should click every time. This tests the TCC PWM solenoid circuit per P1860.
Get back to me on these tests. Here is a diagram that may help.
Old 09-07-2015, 08:40 PM
Here is a Pressure Switch Manifold diagram.
Circuit status (Engine running).
Old 09-09-2015, 01:52 AM
LsXRs's Avatar
I will do these tests asap. Its being super hot lately here can't even do anything outside.
Quick Reply: 4l60 wont shift out of first
