LQ4 with BOP th400 questions????
Old 09-27-2015, 10:12 PM
Billy Pope's Avatar
Default LQ4 with BOP th400 questions????
2005 LQ4 mated to BOP th400. I'm looking to bolt a LQ4 to a Buick, Olds, Pontiac th400 transmission. I already have the adapter plate and GM spacer to bolt it together. What I'm wondering if this is everything I need or am I missing something else?? Ive read articles and have yet to find a straight answer on the exact parts I need to make it work properly. Any help will be greatly appreciated. Thanks
Old 09-28-2015, 10:14 AM
john kilgore's Avatar
be careful about tc to flex plate spacing, around 3/16" gap
Old 09-28-2015, 07:31 PM
clinebarger's Avatar
Those adapters are Silly. A very good way to bust a trans case.
The Dowels will be too short, You will only have 2 bolts going through the Case into the Block.
Chevy TH400 cases are prolific, Swapping cases is easy & simple mods can be done to beef up the trans (Namely dual feeding the Direct Clutches).
Old 10-02-2015, 06:13 AM
forcd ind's Avatar
I guess your using the BOP because you have it
Not sure on the prices, you could always swap to an
SFI bellhousing, solve 2 problems
Old 10-02-2015, 09:44 AM
Moderator
mrvedit's Avatar
Agreed!
With Craigslist, ebay, forums and other easy ways to buy and sell used parts, it seems silly to try to mate a BOP trans to a Chevy when you can easily sell that trans and buy a proper Chevy trans.
Assuming you are in the US, Canada and perhaps even Australia.
Old 10-08-2015, 01:23 PM
Moderator
jimmyblue's Avatar
I had an old '63 Caddy that had some kind of funny
trans - either switch-pitch or something like it, that
gave it some decent low range and still low RPM cruise.
I think it differed from the TH400 fat cars I had at the
same time (455 Olds 98). I think given all the effort,
a 4L80E would be a much superior option (unless you
are trying to go carb and standalone ignition, in which
case you'd then also need a standalone controller). But
an HD pickup package, LQ4/9 plus 4L80E plus PCM,
would be about as straightforward as swaps can get.
Quick Reply: LQ4 with BOP th400 questions????
