Turbo 400 what's your thoughts
Hey guys this has prob been covered many times thinking of switching from my T-56 to a turbo 400 car has 373 gears use it as a street strip car. How are you liking the 400 for cruising on the street any input would be great TIA
Moderator
Leave your T-56 in 4th gear (1.00 ratio) on the highway and that is what your TH400 would be like. Bet you would hate it especially with the otherwise-nice 3.73 rear.
Best thing I EVER did was switch over to the TH400. It does rev higher cruising down the highway but no significant difference in mileage. Absolutely love my th400. Everyone has different ideas on tolerability. As far as driving around town etc it's better in every aspect in my opinion. Best of luck on a decision that works for you OP
While a 400 is a great trans, I feel your going backwards in rem. an OD trans in this day and age-if anything, go to a 4L80E
I have been using the 80E's in the past few muscle cars I have built, the latest project I used a 400 due to space, and I can tell you I really miss the OD-not only OD but the lockup feature also.
In my 72 chevelle (6.0, Procharger, FI) I pulled down over 24 MPG on the highway, reduced engine noise, etc-expensive, but dam it is nice, lol
You can enter your ratios and such and this site will calculate your cruising speeds.
http://www.grimmjeeper.com/gears.html
Ya I guess there's pros and cons to everything I don't cruise the car as much as I use to more local and at the drag strip want the comsistentcy of the auto. I hear all diffrent things about the 4l80 swap to a f body some say it's a pian others say it's not to bad
How was the 80e swap to do is there a lot of pounding of the trans tunnel I've looked threw a lot of post but everyone says diffrent things. Do you use a manual valve body or what's controlling your shift points
Mine is ran on the stock PCM. I did a segment swap from HPTuners and very minor wiring (my car was a M6). There is the relay mod you can use as well to run it on the stock 60E tune though. There's a few threads on it here somewhere.
There wasn't much pounding at all IMO. Mine is an early year 80E so it has the trans cooler lines upfront which makes it a bit easier as well. Did have to cut out a small section for the trans plug though.
The guy I bought it from told me about Speartech.
Speartech sells a 4L60E-to-4L80E plug and play adapter wire for the PCM issue. Plug it in and thats it.
