4L80E leaking from tail shaft seal/bushing
I have a Jakes Lvl 5 4L80E that's been in the car for about 5k miles now and for the past several months of driving it will leak/push out fluid only during hard acceleration. There is no fluid in front of the tailshaft so I've narrowed it down to there. I've done tons of searching on the subject and results are few and far between.
Attached is pics of the yoke and bushing, and looking to ask the experts what would cause a hot spot on the bushing to make it blacken and the yoke to show the wear it has? I did have issues with the driveshaft not being centered in the safety loop and had issues getting it out of the trans. Could the engine and trans be canted a little bit to cause that issue? Motor is an LQ4 on spohn solid motor mount stands with the factory K member, and trans has a aftermarket brace. I think they are all related somehow... Thanks for the help
It will have a little play as its a forced lube bushing. It may be worn though if you're leaking again.
