Yank vs. Circle D Billet Converters
Help me decide. I've narrowed my search down to (2) billet lock up converters. Here are the specs.
$870 Yank SS 3200. 9.5" diameter billet single clutch. 34 lbs
$900 Circle D 3200 245mm Pro 1. 9.75" diameter billet single clutch. 37 lbs?
I called Circle D 3 times today but no answer. I am leaning towards Yank.
Looking for opinions only from those that have run these in their car. This is a street driven car with very limited track duty.
Thank you
Thank you
Both are very popular... i have no experience with yank, but i currently have a circle D converter.
This is actually my second converter from circle D. I was running a vigilante 3200. Both of my converters are circle D 5c which is a 4000 stall.
I would highly suggest circle D. The quality of the converter is amazing. Hell, the packaging is amazing.
I would also suggest stepping up to a bigger stall. Try calling circle D..go with circle d. You wont be disappointed
Thank you
Thank you
circle d for sure..there customer service is awesome and there converters work dam good..and yes we had a big storm come threw Houston a lot of businesses are closed..give them a call tomorrow I'm sure they will take care of you
1986 Olds 442
Weight: 3650
Drag Radials
Tire hieght: 26"
Rear gear: 3.73
Transmission: 4L80E
If the car runs high 11's I will be happy.
Thanks for all the responses. The engine is a 2009 L92 6.2L with a Texas Speed VVT 1 cam kit, headers and tune. Based on TSP dyno curves, the RWHP should be around 450. According to Texas Speed, a stall converter isn't required due to the low end provided by VVT cam. Here are some more specifics on the car:
1986 Olds 442
Weight: 3650
Drag Radials
Tire hieght: 26"
Rear gear: 3.73
Transmission: 4L80E
1986 Olds 442
Weight: 3650
Drag Radials
Tire hieght: 26"
Rear gear: 3.73
Transmission: 4L80E
I bought a Yank PT3800 triple for my 4l80e swap and currently rocking a 3200 Circle D with the 60e which I've been very happy with. Honestly out of Circle D, Yank, or FTI as well, I'd just go with whatever is the cheapest that day. They all rock and have great customer service.
in a different stall converter thread circle d posted pics of his work and they look terrific, you should check that out before you decide. just my one cent. searching found a thread torque converter education post #3 has a few circle d pics.
No Problem Chris....Thanks for the heads up. I sent you a pm with lots of questions.
