No TCC lockup after 4L80E rebuild due to failed alternator
Old 04-24-2016, 10:28 AM
Vetal's Avatar
Default No TCC lockup after 4L80E rebuild due to failed alternator
I had alternator failure and that caused most of my clutches and steels to burn completely. Had my 4L80E rebuilt by a shop but since then I can't get my TCC to lock when commanded, even manually applying ground to TCC wire doesn't make it lock. Before the transmission was pulled out, TC was locking properly.
I'm a little desperate at this moment since shop who did the rebuilt has no idea. I've checked TCC solenoid with pan off and it clicks. I wanted to get the lockup valve out of the pump (through the pan), but it doesn't want to come out after locking ring removed
What else can I check? Is there any way to remove lockup valve out of the pump?
Here's the video of the lockup valve moving but not coming out:
Old 04-24-2016, 10:31 AM
LLLosingit's Avatar
How exactly does a bad alternator cause you to burn up a transmission?
Old 04-24-2016, 11:31 AM
Vetal's Avatar
Because of low voltage in the system solenoids presumably provided less pressure to the clutches allowing them to slip under full power
Old 04-24-2016, 03:30 PM
LLLosingit's Avatar
Hmmm... I was always under the impression that if the voltage is to low that the trans goes into limp mode. I could be wrong though.
Did you also get the converter flushed before you reused it?
Old 04-25-2016, 02:32 AM
Vetal's Avatar
Yes, I got it flushed (with petrol, as far as I remember)
Old 04-25-2016, 07:40 AM
built408's Avatar
Alternator did not cause your issue.
Old 04-25-2016, 10:47 AM
Ratdaddy60's Avatar
[QUOTE=built408;19236780]Alternator did not cause your issue.[/QUO
Low voltage causes max line pressure.
Old 04-25-2016, 11:07 AM
Vetal's Avatar
Alternator died, and the next couple of runs transmission started slipping.
Old 04-25-2016, 11:48 AM
jakeshoe's Avatar
Low voltage can cause transmission failure.
Old 04-25-2016, 11:50 AM
jakeshoe's Avatar
[QUOTE=Ratdaddy60;19237038]
It also causes other issues. Voltage doesn't just run the EPC, and on a unit with fixed line pressure, the EPC is irrelevant anyway.
Old 04-25-2016, 03:29 PM
Ratdaddy60's Avatar
[QUOTE=jakeshoe;19237151]
A bad ground in the TCU might cause transmission damage over an extended period of time. Ok, so a unit with fixed line pressure wouldn't be effected by low voltage. The shift solenoids either work or don't.
Old 04-25-2016, 03:33 PM
Ratdaddy60's Avatar
Use a small drill and drill into but not all the way through the aluminum plug. Screw a small sheet metal screw into the plug then you can use a pair of pliers to remove the plug.
Old 04-25-2016, 04:25 PM
jakeshoe's Avatar
[QUOTE=Ratdaddy60;19237476]
I've probably built more transmissions than anybody posting in this forum.
4L80Es specifically.
So let me break it down simply for you.
What happens to the shift solenoids when they lose voltage slowly, as in a battery that is constantly losing voltage throughout a run, while the fuel pump, OK injectors, and coils are drawing on it?
Old 04-25-2016, 04:49 PM
Ruler_Mark's Avatar
Can confirm the 4l80e is not happy in 3rd when you run out of volts. Stopped us from breaking into the 8s last year.
Side note jake can double confirm cause he had "fun" dealing with the trans smellzzz
Old 04-25-2016, 07:45 PM
Vetal's Avatar
My transmission completely burnt 2nd gear clutches IIRC.
Anyway, any advices what to do next? Shops says "cut the converter", but I don't believe it's TC not locking...
Old 04-26-2016, 02:47 AM
Vetal's Avatar
Do you mean I should drill into the lockup valve to remove it??
Old 04-26-2016, 11:30 AM
Ruler_Mark's Avatar
Cooler always has to be flushed and converter cut when debris enters the system. Stuff can stay trapped ez in the converter
Old 04-26-2016, 05:46 PM
Hi-Po's Avatar
Just so I understand better... on a stage 5 build where the line pressure is a fixed value, will a weak/dying alternator hurt the transmission?
Sorry OP, I'm no help here.
Old 04-26-2016, 09:59 PM
jakeshoe's Avatar
Yes it is possible under certain circumstances.
It's not a problem caused by pressure control.
Old 04-26-2016, 10:31 PM
Hi-Po's Avatar
Thanks Jake. Just trying to not call you with a problem, ever lol.
Quick Reply: No TCC lockup after 4L80E rebuild due to failed alternator
