Help chose converter for cam
Hi hows it goin im looking for a bit of info on how to choose best converter stall, and also which if any possibility best around 500$ (with links)
224/230 .612/.612 116 lsa
Thats the cam im running ls2 heads. Chromemolly pushrods, dual springs titanium retainers , ls7 lifters
I wanna get torque converter and intake manifold b4 tune.
No super charger i bought head and cam off guy who had trailblazer ss.
With that cam a 3600 would be perfect.
But i will tell you, after awhile you will wish you went with a bigger stall. You can easily daily drive a 4000 stall.
I had a vigilante 3200.. I swapped it for a circle D 5c converter... it drives just as civil but pulls like a monster..
Oh really nice? What else you running and the giy topd me 28-3200 would be perfect for cam but both of you say 36 is good what are your cam specs ?
kind of off topic, but that car must suck to drive with that cam and no tune with the stock converter.
228/232 .612/.600 111 Lsa. A 3200 would work fine but like the other guy said, you'll end up wanting more. I like my 3600 but could easy go with a 4000+ and would love it.
You'll get different responses from everyone here asking what converter to go with, but I would go with either a yank ss4000 (I have the ss3600 currently) or FTI 4000 Hit Hard personally. I have heard great things about PTC, Vigilante, and Circle D as well. Either way you cant go wrong with any quality converter.
Also, you will need to run a decent sized transmission cooler. The higher stall converter will heat the fluid up fast so you need to keep temps in check.
