stall question
Old 07-13-2004, 08:41 AM
stevensLS1's Avatar
Default stall question
i am thinking about gettin like a 3000 to a 3300 stall for my car 99 t.a and i was wondering if ima need a tranny cooler?
Old 07-13-2004, 08:55 AM
12secSS's Avatar
I always recommend a trans cooler when running a higher than stock stall converter. The best out there is the B&M 24K trans cooler.
Old 07-13-2004, 09:15 AM
CamaroCain's Avatar
yes, a trans cooler is a must. Look into Vig3200, TCI3500, and the Yank SS series of converters for more streetability. I see you are from Houston, how often do you go to HRP?
Old 07-13-2004, 09:48 AM
stevensLS1's Avatar
u are talkin about the track right. if so i havent really had much of a chance due to out shitty weather! i really would like to go soon! im lookin to either get a bigger cam or gears! what do u recommend?
Old 07-13-2004, 10:26 AM
heyitsTaJay's Avatar
i have a 28k cooler and couldnt be happier.
J
Old 07-13-2004, 03:08 PM
stevensLS1's Avatar
J
hey man how much did u pay for that tranny cooler? just curious
Old 07-13-2004, 03:49 PM
look to spend around 60$. i read that your thinkn about a bigger cam or gears. u need to stop. read. search. then move forward. u REALLY need to get aplan of action together instead. think of what you want the converter to do. hit the tires hard, or easy on the tires, or efficeincy? then once u get the converter, look at cam options for a stock car. if your going to do a cam, you will end up having to do more then "just the cam" rockers etc.. and you need to get a cam that matches up with where your converter is most potent. next there is nothing stronger than your stock gears. if you go to aftermarket you are weakening the rear end a lil bit, and the 7.5 rears arent really worth throwing gears in....
Old 07-14-2004, 05:19 PM
stevensLS1's Avatar
well i appreciate the advice from all and especially you! i have just decided to leave the car alone! ive got other plans that really doesnt concern the car! thanks again
Old 07-14-2004, 07:53 PM
glad i could be of assistance! good luck with your other plans!!!
J
