PCM tricker for a4 to TH400
Old 07-23-2004, 09:02 PM
Roadrunner 45's Avatar
Default PCM tricker for a4 to TH400
I'm gonna go TH400 instead of the 4L60E. I read a blurb in another post about a Yank "PCM Tricker". Anyone have info on this? Does this prevent the need to reflash to an m6 program?
Old 07-25-2004, 04:26 PM
Spl170s's Avatar
I have found a price in their website...but that was it. No real info on it and how it works. Price looks to be in the $250 range. Which from what i am seeing you can get a good tuner to reflash to a M6 program on your computer for less....maybe.......
Old 07-25-2004, 04:33 PM
MeanWS6's Avatar
who is building your TH400 and what options are you going with.
I think the best way is to just flash your PCM with an M6 tune
Old 07-25-2004, 05:37 PM
I'm likely gonna go with the TCI Competition 400 out of Jegs/Summit. I had one in my last car and it performed flawlessly. I also just heard from a friend that he'll give me his TH350, but it will need to be built before I slap it in or it isn't gonna last. I'm trying to figure out what'll be the best way to go.
Can I do what I need with the HP tuners software too? I'm really trying to avoid relying on tuners/speed shops anymore.
Old 07-25-2004, 06:19 PM
T/A Medic's Avatar
you just get a m6 file for your year car and flash it...
Old 07-25-2004, 08:09 PM
where do I get an m6 file? Can HP Tuners software flash it?
Old 07-25-2004, 08:21 PM
T/A Medic's Avatar
you have to find someone with a save M6 file...
Old 07-27-2004, 04:49 PM
Ok, I saw a '99 file for a M6 in the tuning section-
Is it just as simple as copying that and then flashing it to my '99 auto PCM?
Old 07-27-2004, 04:55 PM
12secSS's Avatar
If you have an A4 and are swapping in a TH400, don't use the M6 file ... just buy the GM parts that bolt in to your TH400, this provides the computer with the necessary signal it needs. Otherwise with the M6 file, you need to multiply the signal by 2.5 times for the speedo to show the correct speed.
Part numbers are:
sensor: 8655291 - replaces speedo cable drive on TH400
reluctor: 8655315 - goes inside trans (TH400)
pigtail: 12085498 - splices on to your OE harness
Old 07-27-2004, 06:49 PM
I was more referring to the PCM thinking the car was always in Park with the TH400 'cause it isn't getting a signal from the trans, thus is doesn't use the correct spark/fuel maps for a "loaded" state (I am VERY inexperienced when it comes to tuning, so please correct me if this is not an issue).
I really don't care if I have a speedo working or not, but thanks for the p/n's.
