Shift kit and no Converter?
Old 08-03-2004, 01:01 AM
My00CamaroZ28's Avatar
Default Shift kit and no Converter?
Right now I dont have the money for both a shift kit and converter, but would it be good for me to just get a shift kit now? Would it help make my car any faster with the shifts or....?
thx for the help.
Old 08-03-2004, 05:31 AM
TeamTripp's Avatar
Its best to do them both, because you can set up the kit to maximize performance from the converter. There is nothing wrong with doing the kit by itself, but if you get a loose converter afterwards, you may want to remove the spacer plate for further modifications to compensate.
Old 08-03-2004, 05:54 AM
MNR-0's Avatar
A converter will nett faster ETs than a shift kit. A shift kit will round off the converter, making shifts firmer. You can also adjust shift firmness in the computer using LS1Edit or HPTuners. Go the converter first.
Old 08-03-2004, 07:59 AM
Ragtop 99's Avatar
a shift kit will not improve ET; at least I have yet to see anyone here demonstrate it at the track. Save the $$ for your converter.
Old 08-05-2004, 02:07 AM
MeanWS6's Avatar
do them both at the same time, otherwise its a waste
