where to find cheetah shifter, and how much?
Old 09-28-2004, 05:52 PM
Z28Maro's Avatar
Default where to find cheetah shifter, and how much?
i have decided to go with the cheetah for my rmvb th400 but don't know who/where sells it. where did you get your's, and what was the cost? thanks. btw, does the cheetah have a way of controlling the trans-brake on the shifter itself? or do you just use a switch as usual? thanks again
Old 09-28-2004, 06:39 PM
Z28Maro's Avatar
also...what is the part number for the shifter....the only number i've found is pn: 70073b which is the gate itself from what i saw on a site earlier. what is the number for the shifter? thanks again.
Old 09-28-2004, 10:21 PM
Navy David SS's Avatar
The part number you need is 70073b - if you are going to the reverse pattern ..
notasponsor.com
I bought mine from Summit
David
Old 09-28-2004, 10:28 PM
Z28Maro's Avatar
David, why did you go with the 70002b? and why would i need the other part number instead? thanks. and what about valvebodies? the trans has a manual in it right now but we're going to a rvmb WITH a brake...who makes a good one? thanks a ton.
Old 09-28-2004, 11:08 PM
Z28Maro
I bought my entire convertion from M6 to A3 from MadMan. Tranny and Converter is from the Trans King oof Texas. Give Brian a call -- he is one of our sponsors and a great guy to work with.
I can't remember exactly the part numbers. I did call Turo Action 1st got the numbers I needed and than call Summit to order. It has been a while. Just call Turbo Action and get the part numbers you need - they were very helpful.
David
Old 09-29-2004, 12:48 PM
Baltimore Whore
Mangled03gmc's Avatar
i'm not sure of the part number but i bought mine from jegs for i think around 300 bucks.it was for a rmvb.it has a button for the trans brake or nos etc right on the shifter handle.
Old 09-29-2004, 01:10 PM
stangeater01's Avatar
jegs is where i bought mine, it does have a button on the shifter i actually set mine up to wher the button serves 2 functions i have a 3 way switch in my ash tray flip it forward the button controls the t-brake middle button serves no purpose (off) down controls my line lock
Old 09-29-2004, 03:43 PM
MeanWS6's Avatar
yes, 70073B TURBO ACTION GM REVERSE GATE PLATE is the one you need
I think 1b was mopar, and 2b was ford, 3b is GM applications.
Old 09-29-2004, 05:43 PM
Z28Maro's Avatar
thanks a million guys....i ordered the cheetah today and an ART CARR valvebody with a brake. hope it works as well as i want it to. thanks again.
Old 09-29-2004, 10:41 PM
MeanWS6's Avatar
what part number did you go with - - -were we correct?
Old 09-30-2004, 05:27 PM
Z28Maro's Avatar
went with the 70002b from JEGS...i think it was actually 912-blahblah from there. i called them today and they said it would work with the t-brake, the rmvb and everything. thanks for the help guys, it's very much appreciated.
Old 09-30-2004, 05:29 PM
Z28Maro's Avatar
70073b i mean...my bad. i was thinking of the other one. but yes you guys were right.
