Lockin the Torque Converter....
Does anyone know of a kit that lets me do this, I know people add a TC lockup switch, but who makes it, or how do they make it? A buddy of mine gain .3 in the 1/4 with it locked. So I wanted to do the same thing, and I can't get a hold of him, and I am impatient.
Thanks guys.....and gals too.
8 SEC SLOPPY SHOT!!!
You need to tap into the computer and tap off the lock up wire or known as the TCC wire. Just run a wire from the computer to a toggle switch and ground it. Just remember when you keep it grounded and forget to flip the switch it will stall your motor so just remember to turn it off when your done.Happy locking it up i do all the time in the big end.
First, if you are not running a turbocharger or supercharger or have a excessively loose torque converter, and you are lowering your ET in the quarter mile, then the torque converter is not matched to your engine/rear end end/tire combination. When a torque converter is correctly matched, you will run the quickest & fastest in the quarter mile with the torque converter unlocked. In every test that we have done, (making comparisons between locked & unlocked torque converters in the quarter mile) the unlocked way were always faster & quicker.
What year is your car. All your going to do is tap off the pcm run it to a toggle and ground it when you want it locked.The only down side is when you manual lock the convertor you will trip the ses light it wont hurt anything juct that orange light in your face.If your car is a diffrnent year i can look and see what pin location it is.
Originally Posted by Nova5
whats the point of locking it?
and for those that feel a lockup converter is not bennefit...you have just never set up/geared a car to make it become a bennefit. but that isnt what im looking to do here. plus with my loose converter...when i do get the lockup fixed on it...it'd be nice to be able to lock it when i want in normal driving.
thanks
As I understand though once the switch is inactivated it will go into normal computer operation. I thought the switch was basically only for when u want to LOCK the converter not to unlock it
Originally Posted by slow3hoe2
well...if it is indeed a wire that i am tapping into...couldnt i just cut it? then when i get my converter fixed...hook up the switch.
Well I'm not really sure on that one, but I think that if the computer doesnt get some kind of input it would just go into a default mode. But I'm sure someone could answer that question completely
DONT DO IT. Most converters used in these cars use a 245mm to 300mm conversion. The clutch in the 245 is NOT strong enough to handle high horsepower for much if any time. I blew up a converter with my lockup switch. It is a BAD idea. As far as cutting time by locking it up, that can be accomplished by changing to a more efficient stater (lower str). To me it sounds like you are just running an ineffecient converter to begin with.
It's the red plug on the computer pin number 42 tan with black stripe. If you disconect it will not lock up intill you get your trans fixed.Then lock that mother good luck. mike
Originally Posted by SmokingWS6
He car isn't fast enough for lockup in the 1/4
