Can transbraking your T400 hurt it?
Old 11-02-2004, 01:16 PM
GrannySShifting's Avatar
Default Can transbraking your T400 hurt it?
if you do it without a 2 step?
Old 11-02-2004, 02:29 PM
12secSS's Avatar
NO! We don't have a two step and she launches at 4000 rpms on the transbrake, where it is designed to launch from.
Old 11-02-2004, 02:54 PM
SmokingWS6's Avatar
There is a way to setup a two step using the stock pcm. I believe there's a way to setup a N and Drive limiter. I've not looked into it but theory you can wire up the neutral/park wire to the trans brake, thus when you lanuch it goes back to drive limiter settings as well as launching the transmission
Old 11-03-2004, 05:52 AM
BTL FED's Avatar
Nope wont hurt it, the 2 step will just make it more consistant. Just dont stay on the brake too long, If I remember correctly when you are on the brake (giving it gas of course) it heats the fluid around 30-50 degree's per second
Old 11-03-2004, 10:24 AM
john kilgore's Avatar
Default tb
an other issue with a trans brake is high line pressure. lf the trans builder used iron sealing rings, high line pressure wears the grooves. if on the other hand he used plastic type they live better. good luck
Old 11-03-2004, 11:17 PM
John, shoot me a pm when you get the chance, quote on a T400 2.75 first, tbrake rev. manual, alum deep pan, shorty tailhousing
Thanks guys I kinda knew the answer to that ? when I asked but Id liek to hear it from other guys that do the same thing
Old 11-05-2004, 05:28 PM
98sspullin'em's Avatar
couldnt you get a vacuum modulator for that??
Old 11-06-2004, 11:23 AM
Default v-m
l have built trans brakes with internal solinoids and that would let you use a vac mod, but l have never had a vm on them. internal solinoids to fudge the rules against tb's
Old 11-08-2004, 01:43 PM
93LS1RX7's Avatar
More like 150-200 degrees/second. You dont want to be on the brake more than 2-3 seconds or bye bye tranny
Old 12-21-2004, 08:49 PM
damn, thats good info to know
