View Poll Results: which cooler ?
B&M
31
63.27%
Hayden
5
10.20%
doesn't matter either one will do
13
26.53%
Voters: 49. You may not vote on this poll
B&M or Hayden cooler?
Old 11-23-2004, 01:10 PM
john shea's Avatar
Default B&M or Hayden cooler?
Thats the question or does it make no difference.
John
Old 11-23-2004, 01:18 PM
Moderator
jimmyblue's Avatar
I have a Hayden. Tubes is tubes, fins is fins, more
is better.
I picked up a pair of the "Perma-Cool" frame-rail types
(long and skinny, with mounting feet) which I plan to
use for a different install scheme, get the cooler off
the condenser / radiator "stack" so it's less obstructed.
They have less area than the max-size brick types
though.
Old 11-27-2004, 11:47 AM
ULTIMATEORANGESS's Avatar
look below.
Old 11-27-2004, 12:51 PM
Pontiacerator
RevGTO's Avatar
I bought the perma-cool frame rail that JImmy describes and plan to do the install documented in this thread:
https://ls1tech.com/forums/automatic-transmission/179082-alternative-tranny-cooler.html.
Old 11-27-2004, 01:14 PM
Jenibella's Avatar
We use the B&M cooler in our cars.
Old 11-27-2004, 07:24 PM
SmokingWS6's Avatar
I use a B&M cooler and average 115 to 135* trans temps with my converter. Low speed cooling fans are almost always on which keeps airflowing through the cooler at at all times.
Old 11-27-2004, 07:36 PM
01Z0H6's Avatar
I too use the B&M 24K.
Works grewat with my SY3500 & deep pan.
Avg. approx. 150-170 deg.
Old 11-27-2004, 08:16 PM
Bill Bowling's Avatar
Thumbs up
I installed the B&M using the Dope Method due to having Cold Air Induction. It keeps the trans temp below 180 all the time.
Bill
Old 11-27-2004, 10:56 PM
sleeperstyle's Avatar
b&m here- dope style install. not sure on the exact temps, but the trans hasn't died yet so the b&m is doing it's job.
Old 11-28-2004, 12:58 AM
Retired Street Racer
Matt D's Avatar
https://ls1tech.com/forums/showthread.php?t=179082.
that style of cooler won't work for guys that have the ftra or ssra. b&m here, no problems.
Old 11-28-2004, 06:29 AM
2MuchRiceMakesMeSick's Avatar
I also have a B&M but it does not matter as jimmy blue said. Its only a heat sink
Old 11-28-2004, 08:31 AM
Ragtop 99's Avatar
plate type coolers such as the B&M supercooler are a better choice then the tube and fin. They generally are more efficent for a given square area and flow less when cold. Thus they allow the tranny to come up to operating temp before providing their full cooling capacity. That is a consideration if you live in the northern half of the U.S.
Old 11-28-2004, 10:31 AM
Suprfun's Avatar
Went with the B&M 24000 GVW on my newly built 4L60e w/ TCI SF3000.
Mark
Old 11-28-2004, 07:25 PM
Pontiacerator
RevGTO's Avatar
But the benefit is the ability to mount it right in the heart of the airstream without stacking it on to the condenser - cooling shoud be excellent. But you may have a point about getting up to operating temp slowly.
Old 11-29-2004, 07:48 PM
Ragtop 99's Avatar
Rev: I'm sure I get your point. You can mount a plate type cooler any place that a tube & fin cooler mounts. The plate cooler will be more efficent.
The exception is a frame rail cooler which is a different shape and designed to be mounted in a different location. Capacitywise, they are fine for smaller converters (no more than 3500) as the 24" is rated for 15,000lbs GVW. Even though it is rated for 15000 GVW, I notice that it has tube length than a typical fin type cooler of similar rating. A frame rail cooler and a good deep pan would work well for those that do not want to block the radiator or use the "Dope" method of mounting.
Old 07-11-2006, 01:50 PM
monicaz28's Avatar
B&M here, no issues. It does its job well.
Old 07-11-2006, 02:04 PM
GregWS6&z28's Avatar
b&M 24K
Old 07-11-2006, 02:15 PM
Rebelord's Avatar
i use a Hayden. Normal mounting style. Works fine, since tranny hasnt died since I installed it. Before, I could kill the 4l60e in a week with a stall and 4.10s.
Ski
Old 07-13-2006, 02:25 PM
SebastianLopezJr's Avatar
This is a pic from when I Installed my B&M back in July of 2004...
Been on my car for two years now on my daily driver with no problems.
Old 07-18-2006, 10:16 PM
1BAD98LS1's Avatar
What are the trans temps supposed to average?? I have a 4L65/ Yank PT 4K with a truck pan and b&m 24k cooler... my mech. gauge usually reads 150ish during street/ traffic driving. Let me know, thanks.
Quick Reply: B&M or Hayden cooler?
