3.23's to 3.73's Who made this swap? How do you like the results?
I already have 3.23's and a converter, but I want to tighten up the looseness. I am considering buying some 3.73 gears. Anyone of you guys had similar set-ups like mine and changed to 3.73's. If so how do you like them? Did they improve you quarter times?
My car goes into 4th at about 120-125 mph on a 6200 rpm shift point...I can't catch 2nd gear from 70 mph anymore...now it's down to 55, it's a big kick in the butt though.
They make driving the car much more fun, but honestly, a good converter doesnt need gears. There are 2.73 geared cars that are just as fast as lower geared cars (numerically higher)....it's really all in the converter.
I made the change when the car was almost stock and before my converter. Gave me only a tenth and 1 mph at the track, but felt much quicker on the street. They're probably helping me more now with the cam. For a bolt-on car I wouldn't bother. They really do tighten up converters though. With my 3.73's and the 2800 Vig, there are people who drive my car that swear it's a stock converter.
Originally Posted by Tom's_SS
3200-3.73 here, my city mileage is 19 and freeway is 23 i drive a little faster than most on the freeway 75-80. the engine turns 2300 RPMs at that speed.
Tom
Tom
Originally Posted by WJ SOM SS
Tom: Can you, or anyone else, tell me how much your RPM's increased over the 3.23's after installing the 3.73's when crossing the finish line of the 1/4 mile? Ever glance at the tach when crossing finish line? Thanks. WJ Oh, that woud be w/a 26" tall tire, also.
Originally Posted by WS6RAGE
I have all basic bolt on's in my Automatic WS6 do you guys think i could just keep the stockrear end and dump 3.73 gears in it-or should i just get a 12 bolt?
You think that will do it? I keep hearing that the rear ends on those cars junk and if i add any real power to the car it will brake. If i get a stall for an everyday driver how high should i go? And should i get a tranny cooler while im at it? Thanks for your help!
So what do you think should i just go with a stall n get a tranny cooler? Should i leave the rear end alone or should i dump in the 3.73 in that stock rear end? Im lost i dont know what to do at this point.
Originally Posted by BAIN
I have 3.73's in mine and in 3rd gear at the end of the 1/4 the tach says a little over 6100-6300rpm. I have my shift point set to 6100, rev. limiter at 6400 and in 3rd it will hold it through the 1/4, but if I put it in 4th it will shift before the end. I think I'm running out of gear with the 3.73's. If I were you I would stick with the 3.23's until you put a cam in it and rev higher.
