Tranny Cooler Line Popped Off!!!!!!!!!!
this morning it was below 0 out so it started my car to let it warm up, like most other mornings. after a 1/2 hour i went to leave for work, so i put my car in reverse and nothing: drive nothing. so i started to get a little concerned. i tried running through the gears to see if it would do anything. again nothing. i popped the hood and could see something squirting so i shut the car off. i found the cooler line from my radiator to my B&M cooler had popped off. when i got home from work this afternoon i went to fix the line. got the hose back on and tightened the clamp then started to put fluid in . after 7 quarts its right about where it needs to be . so i take it for a ride and it seems fine. does anyone think i hurt it real bad??????
dont meant to hijack your thread but is there another way to secure the lines to the cooler besides clamps, i have the 70264 cooler and found that the "in" line was really close to coming off the fittings.. are there any adapter i can get for this?
My lines have been trying to come off lately. They are over 2yrs old, I guess they are wearing out. I was warming my car up in the garage to change the oil, when I came back out I had about 3qts on the ground b/c a line popped off. No damage done, it didn't get to low, just a cheap version of a trans flush. lol. I'm going to buy new lines, places like Autozone should carry them.
there had to be some fluid in it because i know if they have none it takes 10 or more to fill or so i read somewhere. i did not hear it whining like a pump would without fluid and so far so good. also both before i started to put fluid back into it and after i refilled it the fluid did not smell burnt. just smelled like ATF. i guess i'll have to keep my fingers crossed.
Just rubber lines from the trans cooler to the cut transmission tubing lines is Mickey Mouse....Earl's and other mfg. make braided stainless tube w/adapter fittings that make a nice, neat job. There are some tracks where tech will not let you run w/those mini-hose-clamped flimsy rubber hoses from trans cooler..... One of those lines blows off on the starting line and blasts a quick 2 or 3 qts. of tranny fluid out, you're gonna have a ton of people ready to string you up by the *****.....That'll usually take 1 or 2 hours to clean up a mess like that....Makes track personnel VERY MAD. WJ
i know what you mean WJ. i was actually going to do braided stainless and correct fittings when i was installing this, but the trans cooler only has the slip fit type nipple on it did not want to have fittings at one end and a clamp at the other. this is the first time i have ever seen a tranny line do this and trust me it was enough to make me sick in the stomach.
Like I said, Earl's and someone else makes a little tool, similar to a flaring tool, that enables you to crimp a little bead down a short distance from the end of the metal tube. When clamped, it prevents the hose AND clamp from slipping of end of tubing. If you don't have access to the tool, at least double-clamp the thing. There's no high pressure there--usually the trans fluid softens the rubber hose over time, or car vibration loosens the stainless worm clamp......and then the line blows off. It can really spoil your day...... WJ
I had this happen to me. Did you buy the b&m kit with the installtion hardware inside? I did and used the clamps that came with them. After a month later the clamps failed and i was pouring tranny fluid all over the road until my car started to rev up an didnt go anyware. I was so pissed. Ive heard this happening to a couple of other guys also. They also used the clamps that b&m provided. I now have a fear that this will happen again so i go under my car and check all the hoses and clamps for slack before i go anwere now.
Well, I am a Mickey Mouse person too. That's how I added in my B&M. And the same result. Fluid running down the side of the street. F*ck. I put 4 clamps on the lines after that.
Are you guys tightening your band clamps with a screw driver or ratchet? I've always found that a screw driver/nut driver never get them tight enough. Tighten the clamps with a socket and ratchet until the outside of the rubber hose actually comes through the slots in the clamp. Mine B&M clamps have been on for a few years with no issues, cold weather and hot.
