Looking for a deep pan for my 4L60E - Recomendations?
Who makes a nice deep pan for the 4L60E's. I want one with the cooling fins and the drain plug in it. If you know Please tell me where they can be found at a fair price. Thanks, Lata, Ark
I know of two places.
http://eastco.tripod.com/id2.htm ask for Steve.
http://www.redrider.us/4l60e_perform...smission_p.htm
I put the B&M on mine.
I have to go back and seal that "extra" fill plug they put on the driver's side. It leaks. Probably needs some thread sealer on it.... Something is covering it now, the shifter linkage I think. So it's easier to seal it before you put it on the tranny....
SO what do you guys think. Aluminum withthe ribs or that steal one withth e cooling tubes? Which would cool better? I think they both add 2quarts so kida the same thing there? WHat do you guys think?
I like the TCI's Al construstion and lots of fins to disappate heat.
Matt: IMO, An extra quart is plenty. Its not the amount of fluid that's key, it's the ability to get the heat out of the fluid. Extra fluid helps if trailor your car to the track so that it is cool before you start racing. However, driving around in town, whether I have 1 extra quart or 4 extra quarts, the fluid temp is going to climb. A good deep pan supplements the cooling capacity of your tranny cooler by rejecting heat from the pan (and the heat is not rejected into the engine bay).
My TCI is a +2 qt. pan. You do not need any pick-up extensions, etc. w/it. TCI makes a 1st quality, rugged piece, and only hangs down a little more than the stock. I also drilled and tapped it for my temp gage sender unit. Plenty of material to drill and tap in the TCI pan.... WJ
