Biggest street driven stall
Old 05-27-2005, 10:20 PM
JZ'sTA's Avatar
Default Biggest street driven stall
What is the biggest street driven stall converter being used on this board?
I see a large amount of people have a 4400 stall. Is there anyone running something bigger?
For those with the 4000+ stall's how is the daily driving on them?
I have a 410 cubic inch motor with 3.73's a 240+ duration cam am I am going NA for a while.
I have a PT4200 siting at my house but have been thinking of going a little bigger. Need some oponion's to see if going bigger is acturally better.
Thanks
Old 05-27-2005, 10:37 PM
BAIN's Avatar
I'm going to a 4800 soon
Old 05-28-2005, 03:06 AM
JZ'sTA's Avatar
Let me know how that works vs the current setup PLEASE.
Really curious how driveable that is gonna be in traffic.
Old 05-28-2005, 07:03 AM
hondakiller's Avatar
been daily driving a pt4200 for about 6 weeks now. doesnt bother me much except in 20-25mph traffic where it wont shift into 3rd. of course, the gas mileage sucks and it makes alot of noise but who cares
Old 05-28-2005, 09:41 AM
CamaroCain's Avatar
IMHO i think that 240 cam makes your car less "driveable" than a higher stall converter. Either way though tuning can make a great big difference in how it drives. I drove with a 4400 stall for a while with no problems. I dont think I would go much over that though, when you start getting that serious you might as well admit its not really a daily driver anymore, JMO.
Old 05-28-2005, 09:58 AM
JZ'sTA's Avatar
Kinda the answer I was looking for.
More or less like you can have a 347 with a T rex, and stage 3 LS6 heads, but once you switch over to 13:1 compression and solid roller you might as well just admit it's a damn race car.
With what my goal is I guess staying below 4500 is the right choice.
My goal is to run mid/high 10's consistantly in a car I drive every day.
Most of the people on this site race their daily driver's, and I would rather post some numbers to compair with everyone else instead of posting numbers that look like a race car setup.
My car is 3700 lb race weight anyways as I haven't ever put the car on a diet.
Thanks
Old 05-28-2005, 11:21 PM
BAIN's Avatar
Really because I thought if you drove it everyday back and forth to work, store, and 10 hour road trips......That it is your Daily Driver
Old 05-29-2005, 02:12 AM
SUX2BU's Avatar
I tried an 8" 4800 and it was WAYYYYYYYYYYYYY too loose. Had it restalled to a 4600. I think it might still be a little to big seeing as how it has a stock cam in it, but i don't wanna send it in for a restall when i do get a monster cam so i'll just keep it.
BTW this 8" 4600 stalls to about 5,500 on the trans brake!
Drive it 90+miles a day and it gets 15/20 (city/highway) in a TH350. not too shabby.
Old 05-29-2005, 11:30 AM
BAIN's Avatar
if it stalls to 5500 on the trans break it's not a 4600 it's a 5500 stall.
Old 05-29-2005, 12:54 PM
JZ'sTA's Avatar
Yep.
Imagin what it was before the restall.
Old 05-29-2005, 01:08 PM
10 & 11 Second Club
Caveman's Avatar
I had a Yank PT 4400 in my 98 Formy. When I put the Vortech on it stalled to 5200. I didn`t like the way it drove on the street before the SC and it was horrible on the street with the Vortech. On motor it was great at the track but too much w/SC, couldn`t get traction. Had it restalled to 3800 by Yank I think it will be much better now.
Old 05-29-2005, 04:27 PM
JZ'sTA's Avatar
ANytime you add a big amount of power like Heads and Cam, supercharger, Nitrous ect it changes the stall of the converter.
That is why Yank has a converter wizard and they have different mods listed.
However a 4600 stalling at 5500 NA is just not right.
Old 05-29-2005, 04:39 PM
Sam88Gta1's Avatar
A tb will allways raise the stallspeed up 900-1000 rpm...You dont base a converter stall off what it will do on the brake.
Old 05-29-2005, 05:04 PM
SUX2BU's Avatar
converters are named a certain stall as a reference point not cause thats what it will stall to. my stall only foot brakes to about 4000(i think) so is it a 4000 stall? nope.
if i put a stroker motor in it would stall even higher than 5,500 on the brake.
So by your logic you can restall and rename your stall by adding more power and not even touching the converter.
Old 05-29-2005, 06:09 PM
BAIN's Avatar
Ok so by your logic a nitrous shot jetted to a 100 shot that produces 130-150 to the wheels is still a 100 shot huh???? Thats's interesting cause to me it's what it puts to the wheels.
My 4400 flashed to 4400 with 381 hp not 5500. I could only foot break it to 3000-3200. They name the stall for what it flashes too.... and yes I know the more power you put to it the stall speed/flash, but guess what... if it flashes to 5500 then it's a 5500 now
Old 05-29-2005, 10:19 PM
CamaroSS's Avatar
I love my 4000 stall form yank....driveability is now perfect since I got another tune on it...the first one made it stay in the wrong gear, or too long, etc. Now the car is in 3rd most of the time, and in 4th when it needs to be. Get of the gas and cruise see it drop to 2k or less. Cruising on the highway 2k or less. I think I actually get at or better gas mileage than I had wiht the stock converter....stop and go can suck, but I have learned to compensate for it......I personaly have not driven higher than a 4000 so i don't know how they are, but if I can have this converter and it does as good as it has, I don't think I will go with anything else.....not to mention I can still grow into this converter better with more mods.
Old 05-29-2005, 10:29 PM
SUX2BU's Avatar
Your right what do converter companies know about naming converters. we should just rename them after we get them in huh?
Old 05-30-2005, 12:14 AM
BAIN's Avatar
nevermind
Old 05-31-2005, 03:33 PM
JZ'sTA's Avatar
nevermind
HHAHAHA.
Converters conpanies GUESS at the converter stall.
It is after experience that they get more accurate.
If it foot brake to one stall and trans brakes to a different stall the trans brake is the actural stall of the converter.
So if you foot brake to 4000 it means nothing, but because he said he could T brake it to 5500 it is a 5500 stall.
Someone messed up if it was supposed to be a 4600.
Old 05-31-2005, 03:44 PM
BAIN's Avatar
HHAHAHA.
Atleast someone get's it
Quick Reply: Biggest street driven stall
