which converter good for ls6 hot cam
i have camaro 1998 ls1 4a, i installed ls6 hot cam 219/229 lift 525/525 and 342 ring & pinion and other external modifications. i plan to buy TCI conveter 3000 istall from my friend with good price, so is it will work good for my cam or not.
can u advice me !
can u advice me !
How good a price? If 400 or lower, go for it and see how you like it. If higher than 400 save a few more pennies and get yourself a 3500+. You can always sell the 3000 later. Anything under 3500 to me feels like stock and really isn't worth it, but if the price is right, go for it.
i had a 98 with a hotcam and 3.73 gears..i had.. stock,3200,4000,3800 converters..out of all of them..i liked the 3200 the best. althogh my 3800 wasnt bad either..my favorite (which i never had) is my buddies yank ST3500 it drives dam near like stock until you hit it..you cant go wrong with yank..mike is a standup guy and their product is awesome.
matt
matt
hi
i have very important question coz i don't know a lot about modefy a car
i don't know what a converter do so if i replace it with the one i told u about what is tha advantage and disadvantage from installing it and if i leave the stock conveter with hot cam what will happen !
I'll try and answer also.
The 3000 will work great, but like already mentioned a higher stall will work even better. I use a Yank SS4000, work awesome around town and even better on the track. It's even more streetable than the Yank ST3500 I had.
The converter will let the car rev a little higher when you leave the lights allowing the engine to get to it's peak power sooner. The car will accelerate quicker if you can get traction. The disadvantage is a slight loss of mileage around town.
If you leave the stock converter you will probably need to bump your idle up a bit. It will not work as well as the 3000. You will probably have surging issues.
Have fun.
Have fun.
Thanks
Have fun.
Have fun.
fist off get a bigger cam =) and second if it is cheap get it...but if you plan to go with more power later get a bigger stall...i have a 3200 stall and i wish i have atleast a 3800
