Life expectancy of stock trans...
Old 09-21-2005, 02:45 PM
DeViOuSwOn's Avatar
Default Life expectancy of stock trans...
I have my stock trans still in the car. It has about 64k on it, never beat on or abused. I am going with a 3600 stall with a 2.8 str ( small gears as of now). How long would I expect for this stocker to last me. Not beating on the car just havin a little fun.
TJ
Old 09-21-2005, 03:18 PM
Roarin_8's Avatar
The stocker will last till you add more power to it. Just make sure you get a cooler with that stall or your stocker won't last at all.
Old 09-21-2005, 03:24 PM
DeViOuSwOn's Avatar
I was thinkin a 19000 cooler?
Old 09-21-2005, 03:30 PM
Roarin_8's Avatar
I've got B&Ms 24K cooler, I suggest you get the same.
Old 09-21-2005, 03:34 PM
DeViOuSwOn's Avatar
True, for like 10 bucks more, be as "cool" as I can I guess.
DeViOuSwOn's Avatar
Will a small to medium sized cam change that? Again I don't really beat on it very much.
Old 09-21-2005, 03:53 PM
Roarin_8's Avatar
I don't know about that. I personally would build up the tranny first before I do any internal work. Just think, you can have a built tranny and the car will run great or you can put a nice cam in the car and if you lose certain gears in your tranny, the car won't run great.
Roarin_8's Avatar
Oh and also, once you do put that cam in, you are gonna want to beat on the car (temptation) but then you'll always have in the back of your mind if your tranny is holding up.
Old 09-21-2005, 05:23 PM
markp03's Avatar
i am running 470ish hp at the wheels with my N2O and mine is still holding up....but this weekend i will be going to the track, and running around 520 at the wheels...i will let you know how it holds up...or blows up =)
Old 09-21-2005, 05:28 PM
Roarin_8's Avatar
How many runs with the N2O? Let us know how everything goes. I'm sure that over time the tranny will go since N20 isn't constantly used. Or is it?
Quick Reply: Life expectancy of stock trans...
