HELP PLEASE!! NO Second Gear
Hey guys, I have an S-10 4x4 with an LS1 and was out driving it a bit today working on some tuning and after a couple of runs I don't have 2nd anymore! At partial throttle it will shift to 2nd but not until like 5500 RPM and then it just revs but doesn't engage. I have tried to manually engage 2nd within EFI Live and it won't engage at all. When in Drive it will shift but not until high RPM's and just skip 2nd and go to 3rd and load it up. Any suggestions? I was wondering about the shift solinoids. I can't believe I would of fried a clutch that fast. The damn thing is a new build. I scanned it with the Predator and found no codes but haven't looked for any codes with EFI Live yet. It's a 4l60e built with probuilt automatics top kit up to like 650 hp. Just trying to figure out what I should be looking for or what to try. Thanks in advance.
Chris
Chris
What ur gonna need to do (unfortunately) is generate a code to help you diag. this. if there is a bad shift sol or stuck valve it will give a code w/enough drive cycles. do you have forth whn it finally shifts to 3rd.? if you do then you know the 2-4 band itself (mechanically) is working.
Lemme know.
Lemme know.
Yes, I'm pretty sure it has 4th. I'll have to double check. I didn't know these trannies had a limp mode. Is it a limp mode to protect itself like the Allison's have? How does it work and what would cause it? To much power, lose of traction, slipping, etc.? I'll keep driving to try to get some codes. Thanks a lot.
Chris
Chris
I have 4th but sill no codes. I'll be driving it some more tomorrow so I'll let you know. I'm really starting to think it's a bad solinoid but I thought I had those replaced when it was built. I'll have to check. Thanks
Chris
Chris
I haven't gotten a chance to work on it yet. I talked to a buddy of mine and he said most likely it's a stuck valve, bad solinoid or O-ring. Gonna take it off and check it this weekend. I'll let you know. In the meantime I wouldn't drive it much considering it will burn out the clutches. Thanks
Chris
Chris
Chris
Chris
Well it's not a solenoid or the band. I think it's a problem in the valve body. I can force the shift with EFI live but it just revs up and doesn't engage at all. I'll let you know what I figure out about the valve body tomorrow. Thanks
Chris
Chris
