tailshaft seal
Old 12-11-2005, 10:12 PM
slimcracka's Avatar
Default tailshaft seal
ok my tailshaft seal is leaking and im planing on changing it and i want to know how hard it is and how would i go about doin it.. i know you have to pull the drive shaft and then what? thanx and any tips would be great thanx
Old 12-11-2005, 10:22 PM
keliente's Avatar
Remove driveshaft. Remove old seal, install new seal It's simple.
Old 12-11-2005, 11:36 PM
99HUGGRSS's Avatar
you also have to remove the yoke to get that seal out!! and there is a torque spec. to put the yoke back on. if you want to get technical!!! it's a rotational torque thing for the bolt on the yoke for the crush sleeve. so your pinion shaft isn't slopping around.
Old 12-12-2005, 01:33 AM
Restricted User
CAT3's Avatar
Wrong part. He said tailshaft, not pinion seal. Tailshaft is stated on first reply, my only suggestion is to loosen the crossmember bushing bolt and raise the rear of the trans to keep fluid from leaking during R&R.
Old 12-12-2005, 03:03 AM
99HUGGRSS's Avatar
whoooooooooops!!!!!!!!!!!!!!!!!!!!!!my bad
Old 12-12-2005, 05:38 PM
slimcracka's Avatar
or i could jack up the rear of the car to crawl under neath it thanx guys...
Old 12-13-2005, 01:35 AM
Restricted User
CAT3's Avatar
True dat, but I have been spoiled lately having a lift available and all
Old 12-13-2005, 07:01 PM
slimcracka's Avatar
Old 12-14-2005, 12:47 AM
Restricted User
Automatics's Avatar
The vast majority of times if the seal is leaking, the bushing will have to much clearance. Replace the bushing with the teflon type, and use the Vamac 3-lip rear seal. Make sure the driveshaft yoke is perfectly smooth & round (close to a mirror finish) where the seal & bushing ride. I hope this helps.
Quick Reply: tailshaft seal
