Replacing stock transmission lines... braided steel?
Old 01-02-2006, 12:10 AM
xjarayax's Avatar
Default Replacing stock transmission lines... braided steel?
Anyone have any general advice on this? Where to get parts, size, fitting, etc?
I took out the stock hard lines when I put in my new transmission but the rubber hoses I am using now.... well, I don't feel the most confident in.
Like I said, suggestions are definitely appreciated. Search is down and not helping me.
Old 01-02-2006, 04:06 PM
xjarayax's Avatar
let's hear it.
Old 01-02-2006, 04:49 PM
EDS01SS's Avatar
Here is what is on my car.....4ea- 3/8JIC Fitting
2EA- Adapter hi pressure 1/4MPx3/8MJIC adapter
2ea- Adapter hi pressure 3/8MPx3/8JIC Adapter
12FT- Hose,steel braided 3/8
the total price on all that was 127.00 with labor to have 2 6FT hoses made.
Old 01-02-2006, 09:15 PM
Moderator
jimmyblue's Avatar
Rubber can be bad news, I've had the patched
together trans lines on my El Camino blow off a
couple of times. The Powerglide wasn't hurt (any
worse) but it's embarassing and will strand you
(I keep half a dozen bottles of ATF behind the seat
along with a nut driver for the hose clamps).
What's wrong with hard flare line? Buy it in segments,
bend it to fit, use some unions where needed. Probably
outlast braided line, probably outflow it (braided line is
well over the pressure rating needed, and a lot smaller
inside than it looks), certainly cost less.
Old 01-04-2006, 11:58 AM
xjarayax's Avatar
thanks for that so far, anyone else have any opinions, links, pictures? etc
Old 01-04-2006, 12:38 PM
BlackHawk T/A's Avatar
It doesn't have that same show quality as braided
Quick Reply: Replacing stock transmission lines... braided steel?
