Getting the speedo to work in a M6 to TH350
Old 01-25-2006, 10:32 AM
EvoByDarwin's Avatar
Default Getting the speedo to work in a M6 to TH350
Ive got my TH350 running good but dont have a speedo. Ive found some info on what to do when making a speedo work going from A4 to A3 but not M6 to A3. Ive got the 9" tailshaft if that makes any difference. Please include P/N's if you can.
BTW, Ive searched but it seems as if some terms still arent working in the search function.
Thanks guys!
Old 01-25-2006, 11:51 AM
LS1TECH Sponsor
Steve Burger's Avatar
Call Billingsly racing and tell Jay I sent you. His trans guy can get this set up with the parts no problem. They did mine.
Old 01-25-2006, 12:52 PM
DAPSUPRSLO's Avatar
How bout for a short tale 400? Is whatever done the same for both? Thanks.
Old 01-25-2006, 02:24 PM
LS1TECH Sponsor
Call Jay. Not sure on the 400.
Old 01-25-2006, 08:28 PM
SUX2BU's Avatar
There a super easy and free way to get your speedo to work but you'll lose your ABS.
Old 01-26-2006, 12:12 AM
Can you give me that super easy way? My ABS isnt hooked up anyway.
Old 01-26-2006, 07:44 AM
DAPSUPRSLO's Avatar
Show me too, 4.56 gears and spool don't care about abs too much, ha ha.
Old 01-26-2006, 05:39 PM
SUX2BU's Avatar
take your speed sensor wires and splice them into your front wheel sensor. program your tire diameter to be EXACTLY what your front tire is. ( phisically measure the circumference of the tire and divide it by 3.14) if you guesstimate it won't be as accurate. And if you had a T56 put in 2.76 for your gear ratio.
