how much fluid in a 4l60E?
Old 02-06-2006, 11:17 PM
punkisntdead's Avatar
Default how much fluid in a 4l60E?
i took the pan off and changed the filter, when i put it back in the car i put 4 quarts in trans. and 1 quart in the converter. now when i put it in gear its like it doesnt wanna go i gotta get on the gas pretty good so it'll start moving. does it just need more fluid? it did sit for almost a year before i put it back in.
also whenever i put it in gear a little fluid comes out the front on the ground?
Old 02-07-2006, 08:14 AM
Dustin 98TA's Avatar
Was the trans completely drained? What does the dipstick show?
Old 02-07-2006, 08:52 AM
DannoWS6's Avatar
Bone dry it will take like 10-11 qts
I blew a cooler line last year and replaced like 7qts. I am sure you need more.
Just keep checking the dipstick.
Old 02-07-2006, 11:11 AM
chrs1313's Avatar
when i changed the converter it took around 8.5-9 quarts
Old 02-07-2006, 05:22 PM
i checked the dipstick and nothing was on it so i added a quart and it goes into gear fine, a little hesitation when going from drive to reverse. now when i put it in park it starts to leak right under the converter? a good size puddle too.
Old 02-07-2006, 07:12 PM
slimcracka's Avatar
front seal is gone..time to repull the trans and pull the converter out and change the front seal that sux!
Old 02-07-2006, 07:50 PM
gettinthere's Avatar
It'll take 10-12 quarts total. It doesn't wanna move b/c there isn't enough fluid so the converter is slipping real bad. As you add more it'll get better. Throw in a few more and then drive it. Keep adding a quart at a time untill it doesn't slip anymore.
Old 02-09-2006, 01:30 AM
SS DNA's Avatar
I just did the same thing to mine, Pulled the pan off and replaced filter.
Now, I dont know how much to add ! Should I just add 5 quarts ????
Old 02-09-2006, 10:57 AM
Put 5 in at first. Then start the car and let it warm up. Add 1 quart at a time until it's full.
Quick Reply: how much fluid in a 4l60E?
