Part # for GM deep pan
Moderator
Here's what I saved; there are a couple of P/Ns shown, I'd
verify the plug deal. Although no longer "current" I have had
good luck Googling GM part numbers and turning up sellers.
The pan I have is off an '02 Silverado.
Truck Pan & Filter:
The pan/gasket kit should be #24215535 and the filter/gasket
kit for that pan should be #24208576.
The filter is specifically for deep pans and will not fit with
your stock pan.
ACDELCO 24204278 [TRANSMISSION PAN] PAN,A/TRNS FLUID OEM#24204278 $38.25
ACDELCO 24215535 [TRANSMISSION PAN] PAN,A/TRNS FLUID OEM#24215535 $47.81
24210915* - This deep transmission pan holds approximately two extra
quarts of fluid and can be used on any 4L60 or 4L60E
transmission. 2000 Silverado
24208576 - Oil Filter Kit (Filter, Pan Gasket, O-Ring).
Truck Pan & Filter:
your stock pan.
