Auto Trans VS. maunal 6 speed trans driveshaft length
Old 02-22-2006, 05:15 PM
92RS98TA's Avatar
Default Auto Trans VS. maunal 6 speed trans driveshaft length
Is the driveshaft lenght the same for athe automatic trans as the manual 6 speed in 98-02 F-bodies?
Old 02-23-2006, 09:43 AM
jmm98LS1's Avatar
yep
Old 02-23-2006, 11:12 AM
12secSS's Avatar
It is actually the same length from 1983-2002, regardless of A4 or M5/6.
Old 02-24-2006, 06:04 PM
92RS98TA's Avatar
thanks guys
Old 09-21-2006, 05:38 AM
V8 Supra Builder's Avatar
I was going to go with a used Inland Empire 82-02 F-body alum DS but in order to save a few $, I'm trying to adapt an F-body DS to my TKO/Supra (plus I haven't heard from the seller in a while). Can one of you with a stock DS measure the u-joint center to center distance & post it here?
Thanks.
Old 05-11-2013, 08:06 AM
Hulkls1's Avatar
Hey I have a 2001 z28 m6 with heads and cam I just put a ls7 clutch kit in and I going to put a 125 shot on the car but I have a alum drive shaft . I know there junk but I have a steal one out of a 98 ws6 auto will that work?
Old 05-11-2013, 11:32 AM
Blackpanther99's Avatar
Yep should work.
Old 05-12-2013, 09:10 PM
ThumpnZ28's Avatar
Never had any issues with my factory aluminum driveshaft. Went A4 to M6, now to 9" and TH350. Length is fine and works like it should.
Quick Reply: Auto Trans VS. maunal 6 speed trans driveshaft length
