Race Prepped 4L60E
Old 02-22-2006, 10:17 PM
Cbrakllr's Avatar
Default Race Prepped 4L60E
Hey everybody, Does anyone know where I could find a race prepped 4l60e besides speedinc.com? I need one that can handle up to 600h.p. before I upgrade to a 400.Thanks.
Old 02-22-2006, 10:26 PM
FLT
FLT's Avatar
FLT-www.finishlinetrans.com-.......... FLT.
Old 02-22-2006, 10:28 PM
SUX2BU's Avatar
Do it right, do it once. just spend the $$$ on a 400.
Old 02-22-2006, 10:42 PM
Cbrakllr's Avatar
i did have a race prepped 400 that i bought but it seemed like too much work too install, bolts didnt fit to motor, longer than the stock 4l60e, crossmembers didnt place right, it wasnt computer controlled, I would much rahter go with a 400 but I dont know what to but to make it work and all that stuff.
Old 02-22-2006, 10:51 PM
SUX2BU's Avatar
Hell you could buy a th400 and all the parts you need to install (even the converter) it for the price of rebuilding a 4L60E to handle some real power.
And if you already have the 400, hell thats just $$$ in your pocket.
Old 02-23-2006, 03:34 AM
BlackHawk T/A's Avatar
Old 02-23-2006, 12:12 PM
Retired Street Racer
Matt D's Avatar
Yeah but he is not a sponsor on here, so you shouldn't be posting links to his site.
Go with Chuck at FLT. One of the best when it comes to performance transmissions and his cutomer service is second to none.
Old 02-23-2006, 12:46 PM
FYI Chuck at FLT and FLP is the same guy.
Old 02-23-2006, 06:03 PM
BBBBadSS's Avatar
I'm getting mine from FLT. Chuck said his level 4 4l60e will handle 600hp.
Old 02-24-2006, 09:11 PM
Deeavi's Avatar
TCI says that their Super Street Fighter will also handle 600 hp. I am considering buying one of them:
http://tciauto.com/transmissions/index.htm
Old 02-24-2006, 10:18 PM
SUX2BU's Avatar
Remember guys they probably mean 600 flywheel HP.
Old 02-24-2006, 10:52 PM
Old Drag Racer
Smokinstorm's Avatar
...and they probably also mean it'll handle that much power for only a couple of miles down the road or a couple of passes down the track. That's what I've run into anyway.
Old 02-25-2006, 03:36 PM
99SeanWS6's Avatar
ive been recently having problems with my 4l60e from FLP. its a level 4 and ive had it for about a year now. not sure what exactly has been going on though
Old 02-25-2006, 03:38 PM
jessedale98's Avatar
How are u guys having trouble, but im not?
Old 02-26-2006, 12:58 PM
BBBBadSS's Avatar
600 rwhp is what he said.
Old 02-26-2006, 01:03 PM
Roarin_8's Avatar
You can also try Dave at Rock-on
BBBBadSS's Avatar
Hey man, I would check out FLT, not that there is anything wrong with TCI.
But there is a $2000 difference.
Old 02-26-2006, 01:08 PM
FLT
FLT's Avatar
Well it comes with a six month warranty! I'm thining your getting more than a couple passes or miles with a FLT unit!!!! I don't think Chuck is scared of 600rwhp. FLT
Old 02-26-2006, 06:29 PM
Deeavi's Avatar
TCI Super Street Fighter: $3000.00 + no core charge
Comparable FLT transmission: $2650.00 + ? core charge
I call that about a $350.00 difference, not $2000.00, and then you have the core charge. I like to see comparable cars with these treansmissions to see which one is best. Probably not much difference?
Old 02-26-2006, 07:14 PM
FLT
FLT's Avatar
371150 PART# 4L60E Super Street Fighter™ 1998-up F-body $3,878.71
NOW THIS THE BEST ONE THEY GOT!!!!
COMPARED TO
4L60E-4 Street Strip–Level 4
Price: $1850.00 (with Exchange)
Options
Vacuum mod kit: $120.00
Deep pan kit: $80.00 (n/a C-5 corvette model)
FLT performance pump
FLT sleeved input drum
8 B/W high-energy clutches in 3-4 pack
FLT beast shell w/bearing
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Bushing kit
All solenoids
Internal wire harness
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated accumulator pistons
Set end play to performance specs
Call Doug Ludwig or Chuck Johnson today at 630-350-7776 for more information.
Continental U.S. residents will receive free shipping for all retail sales on transmissions purchased during the month of February.
So if you add it up it's $2000 in difference. I don't think you had your facts straight.
Quick Reply: Race Prepped 4L60E
