SS3600 + LS6 intake + ET Streets = no gain???
Old 03-11-2006, 10:48 AM
firechicken_98's Avatar
Default SS3600 + LS6 intake + ET Streets = no gain???
I went to the track last night and was running ET streets for the first time on my 98 Formula w/ a SS3600 and 3.23 (mods in sig). The ET streets are a little taller than my stock tires (maybe a +1 in size).
Anyways, I couldn't get my car to launch hard no matter what I tried. I tried brake stalling and I tried flashing, but the car wouldn't launch hard or cut a good 60. My best 60 of the night was a 1.96. The car felt like it was falling on it's face all night. The tires weren't spinning at all either. My car actually feels like it launches harder on my street tires and I can cut the same 60. What gives? Could the change in tire size affect it that much? I haven't ever tuned the car and just recently added an LS6 intake. Someone suggested that torque management could the problem and my tune could be out of wack.
The car also traps kinda low for the mods that I have (104ish) and I didn't seem to pick up any power with the LS6 intake.
Any idea's?
Old 03-11-2006, 10:52 AM
Dustin's Avatar
Have you put a real tune on the car on not that hpp3 crap?
Old 03-11-2006, 10:59 AM
Not yet. I was wondering if that was the problem or just part of the problem. Would that account for the low trap speeds? I'm thinking that I should be in the 108 - 110mph range with my mods.
Old 03-11-2006, 11:00 AM
Dustin's Avatar
Anytime you put a converter in you need to get it tuned. With your mods you could use a decent tune. Im pretty sure that is your only problem.
Old 03-11-2006, 11:27 AM
DSG
DSG's Avatar
I agree with the above. You NEED a tune.
Those mods you should be able to 1.6x 60' every time out, and should net a half a second in the 1/4 no problem.
Old 03-11-2006, 11:49 AM
00ultraz28's Avatar
My car is untuned and I have a camshaft along with my converter and headers. I need a tune baaaad also. But I am cutting good low 1.6 short times and running in the 110-112 mph range... I doubt the tune is all the problem with your car. You might have a slipping trans. That would account for the low 60s and mph.
Old 03-11-2006, 02:12 PM
s346k's Avatar
untuned with only a lid, gears and converter i cut 1.70 short times. only trapped 80 in the 1/8, though
Old 03-11-2006, 04:29 PM
Thanks.
I'm not exactly sure what the problem is. I know a tune is part of it though. It's funny how the car seems to launch harder on the street tires. It's like I'm shot out of a cannon. But with the ET streets last night, it just felt slow.
Maybe this will help some. Last night before I staged, I'd roll through the burnout box, hold the brake and proceed with heating up the tires. When I let off the brake to roll out, my rpms would go to like 5k and the car wouldn't move. Then the rpms would drop to 3k and I'd start rolling. Is that normal with slicks? It never does that on street tires.
I'm starting to think the same thing.
Any thoughts?
Old 03-11-2006, 04:51 PM
slimcracka's Avatar
i think the tune needs to be looked at as well as your tranny is aout to take a shyt...just my .02 thow!
Old 03-11-2006, 05:38 PM
00ultraz28's Avatar
Sounds like to me what happend was when you put slicks on the car and it started hooking, it was too much stress on the trans and it started giving. Look into a good built 4l60 and you'll start seeing some low 1.6 high 1.5 short times. Good luck with everything and get that SOB tuned.
Old 03-11-2006, 10:51 PM
Thanks. That's what I figured too. I'm going to look into a tune as soon as I get the tranny checked out and rebuilt (or buy a new one).
Any suggestions on transmission builders? I hear Rock-on a lot, but I was thinking about getting my trans rebuilt with some beefier stuff.
Any suggestions?
Old 03-12-2006, 03:48 AM
BlackHawk T/A's Avatar
www.finishlinetrans.com
