Just ordered new tranny!
Old 04-04-2006, 11:58 AM
JB00SS's Avatar
Default Just ordered new tranny!
Just now ordered it:
FLT Level 4 4L60E Transmission
FLT performance pump
FLT sleeved input drum
8 B/W high-energy clutches in 3-4 pack
FLT beast shell w/bearing
B/W 29 element sprag
4L65 low roller clutch
Transgo HD-2 shift kit
Corvette Servo
Wide 2-4 band
Bushing kit
All solenoids
Internal wire harness
Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated accumulator pistons
Set end play to performance specs
Installed Options:
Vacuum Mod Kit
Sonnax Super Hold Servo
It should be here in 7-10 days. Now I need to call Yank and order new stall and find a new flexplate!
Old 04-04-2006, 03:01 PM
mpe488's Avatar
Thats the exact tranny I want when I actually have enough power to break mine.
Old 04-04-2006, 03:11 PM
JB00SS's Avatar
I just ordered my stall from Yank. Dave recommended SS4000 STR 2.6. This will hit the tires real good
Old 04-05-2006, 12:13 PM
JB00SS's Avatar
Also got a new flexplate from GM part number 12580709. I thought I should replace it also while I am doing all this work. I have Prothane motor mounts to put in before the new tranny arrives. I also have to get my LCA relocation brackets welded on.
Old 04-05-2006, 01:46 PM
12 Second Truck Club
white1's Avatar
Damn, 7-10 days? Ive been waiting on mine for 3 weeks+, but I got the level 5, and they said it took a while for all the parts to be treated, and machined. Oh well still waiting on my converter anyway.
Old 04-06-2006, 02:09 PM
BLWN1's Avatar
Where in S Indy are you? What do you want for your old flexplate?
Old 04-06-2006, 02:21 PM
rgriffin's Avatar
how much loot did it put you back... shipped to your doorstep?
Old 04-06-2006, 02:54 PM
JB00SS's Avatar
I dont think you would want it. The bolt holes have cracks.
Old 04-06-2006, 03:08 PM
DanZ28's Avatar
Why not the TCI flexplate? The SS4000 is a very nice stall, same one I ran. If you plan on N20, maybe consider the SS4000E?
Old 04-07-2006, 01:24 PM
BlackHawk T/A's Avatar
You will love it. Same one i'm running. Looks like you even copied/pasted from my thread, makes me wonder how much business I did for FLT with that post.
Old 04-07-2006, 01:58 PM
white1's Avatar
Level 5 with the vac mod was $2970
Old 04-07-2006, 02:03 PM
SDB
SDB's Avatar
Should give Rodney at RPM a call, he is in Anderson, IN. I had a $3771 Rossler take a dump, so I had Rodney go throgh it. Much cheaper and very nicely built.
SDB
Old 04-07-2006, 05:38 PM
JB00SS's Avatar
yeah you had the post already typed and I copied it! thanks for the hook up!
