4L80E Manual VB Question...
Old 04-07-2006, 08:36 PM
ThaLS1KidII's Avatar
Default 4L80E Manual VB Question...
I have found that TransGo makes a shift kit that makes the stock 4L80E valve body act as if it was a MVB. I was wondering if anyone knows of an actual MVB that someone makes/sells that is actually a new VB and not just a kit to convert the stock VB?
Old 04-07-2006, 09:03 PM
FLT
FLT's Avatar
The trans go valve body kit works well. If your concerned about a new valve body... most of which will be reworked. If you really want a new valve body it must come from the dealer and then modified.
Old 04-07-2006, 09:41 PM
So the TransGo fully manual VB reprogramming kit works pretty good? Does installing it in turn ruin the VB as far as putting it back to stock? What would you as a tranny builder recommend for this tranny. It is a stock take out 4L80E and I just want to do what I can to it with out breaking it open until I have the funds to have it built. Thanks for the help.
Old 04-08-2006, 05:36 PM
Anybody else?...
Old 04-08-2006, 07:51 PM
chris718's Avatar
we make a bolt in full manual 4l80e vbody.the cost is 675.00 but unlike the transgo it requires that the wiring from the computer be used.there are 2 types of valve bodies depending what year 4l80e you have .there are 2 additional oil pipes on the vbody as well,but nothing to be afraid of .
Old 04-08-2006, 10:41 PM
FLT
FLT's Avatar
Once the transgo kit is installed it can't be converted back to stock anymore. This is because of drilling of passages and other mods. I however would rather have a automatic 4L80e over the manual. But like most shift kit's if it's to aggressive it can be detuned. Good luck.
Old 04-09-2006, 09:20 AM
Josh@KY-Turbo's Avatar
The way I figure it my built 4L65E is not gonna last me very long once I get my car done. I had planned on going with a TH400 w/ FMVB and a T-brake. I dont mind shifting the gears or a hard hitting trans. I do like OD. I like to drive my car the hour and a half it takes me to get to the good race scenes around here. I will probably do a 4L80E with the FMVB for my car. It get me the OD i want and saves me all the trouble with wiring harness and having a seperate computer to control the tranny.
Old 04-09-2006, 11:31 AM
Well that is where I am at right now, trying to figure out if I want to pay for the electronics to make it work or just make it a MVB and forget about the electronics. Looking at the way this post is going I will probably just coin up for the TCI TCU and just put a regular shift kit and a deep pan in it and go race'n. And when I can afford it I will get a Rossler brake for it.
