ATF change question
Old 04-27-2006, 07:17 PM
Midnight F-117A's Avatar
Default ATF change question
Currently I have Dexron III type ATF in my 4L60E, I just picked up 6 quarts of Dexron VI from the local dealership which had it in stock, since I had to order new tensioner for the main and the a/c belt.
I was thinking about when I do the ATF fluid change, the Dexron III type will still be in the valvebody and in the converter, in which the new fluid I'm replacing would be Dexron VI, would it be ok if some Dexron III mixed with Dexron VI inside the transmission until the next change?
Old 04-28-2006, 01:54 AM
joecar's Avatar
It should be just fine.
But if you do want to change ALL you fluid, see this: https://ls1tech.com/forums/showpost....1&postcount=10
Old 04-28-2006, 04:18 PM
Thanks! I just brought a case of Dexron VI for this prodecure.
Old 05-03-2006, 11:05 PM
I just did the filter, added in 5 quarts.
Measured 8 quarts line in the bucket, added 8 quarts while the engine is running and the old ATF pouring out of the cooler line plus some fresh fluid can be seen coming about 3/4ths of the way through to the 8 quarts line.
After checking the fluid (trans cold) the fluid line is like at the looped end of the ATF dipstick. Looks like I'm about 2-4 quarts low on fluid.
Back out to get more Dexron VI.
Old 05-05-2006, 01:10 AM
joecar's Avatar
Sorry about that, procedure should have said to have an extra 3 qts just in case.
I always have extra quarts stocked in my house.
Edit: procedure updated.
Old 05-05-2006, 10:00 AM
That's ok. I had to take my '74 Nova on a 15 min trip to the chevy dealer and pick up 4 quarts of dexron VI.
I used 3 quarts and now it's at the top of the HOT line when the engine is hot.
Old 06-11-2006, 02:35 PM
BlackHawk T/A's Avatar
What do you think of this new fluid?
I can't really find any info on it yet.
Old 06-11-2006, 04:43 PM
So far so good. I can notice the cooler is like just a lil bit cooler than it used to be.
I don't have AutoTap so I can't tell for sure.
Main point with this fluid is that it's supposed to run 15*C cooler and supposed to be better than Dexron III. All of GM new cars and truck uses it unless it's a heavy duty fluid for a truck.
Old 06-11-2006, 11:15 PM
Any difference in the shifting?
TCC lockup feel any different?
Old 06-20-2006, 08:18 PM
Bump.
Old 06-20-2006, 09:09 PM
my94blackz's Avatar
Should you be mixing the 2 like that? 4ish qrts of DexronVI, and the other 10ish qrts dexron III? If your gonna change over Use a T-Tech to flush ALL of one out to replace with the other.
