4l60e Question?
Old 04-28-2006, 01:46 PM
PDub6s's Avatar
Default 4l60e Question?
Is there anything outside of the transmission itself that could cause it to destroy 3-4 clutches. I've already had someone look at my tune to ensure there was nothing damaging there.
Old 04-28-2006, 06:59 PM
Rock-On's Avatar
wow....there are 8-11 external (to the transmission) controllers that have an effect on line pressure which has an effect on the 3/4 clutches...could be several things...hope this helps Dave
Old 04-28-2006, 09:15 PM
SHOPDOG's Avatar
Who's building your tranny?Hope it's not AAMCO! I would probably look to see how the trans is being built. No cross leaks to start with. If it's all tight, look into tuning and engine misfires.
Old 04-28-2006, 10:53 PM
PDub6s's Avatar
Well,
It's not AAMCO. What I'm concerned about is I bought a new GM trans and I want to make sure there isn't anything outside the trans, cooler, converter that could cause a failure. I've already had a reputable LS1 tuner from the area look at the tune and everything appears to be ok, nothing much more than stock.
Rock-On,
What should I look for?
Old 04-29-2006, 10:49 AM
Rock-On's Avatar
In short you should be sure you have proper line rise...you'll need a manual pressure gage to do the test...Take it to a tranny shop after the install and have them check for proper line pressure...cost alittle money up front.... but will save you in the long run...hope this helps Dave
Old 04-29-2006, 03:32 PM
PDub6s's Avatar
Is line pressure rise controlled by the PCM?
