FLP IV tranny goes out again..................
4th one in 4 years and I've never been to a track, street driving only with street tires
Get a hold of Rodney ar RPM....I cracked my $$$$ Rossler 4L60E, and he built me a nice trans...very happy with his work.
http://www.notasponsor.com/
I don't mean to sound like a dick bro, but if you're going to put all that money in a 436 "super stroker" at least go to a built 4L80E or a TH-400 and be done with it If you built that kind of motor and now you have no money for the right transmission then you shouldn't have built such a big motor expensive. A 4L60E just isn't going to cut it. It just wasn't designed to handle that much torque, even street driving. I have a friend with a 4X4, running 44 inch tires with a stock 4.8 had been through 6 4L60E's in 3 years and I wish I could put it through his skull that a 4L80E swap or a turbo 400 is his only option. I mean $6000+ later think of the other stuff he could have done to his truck. That's just my opinion. I just hate to see people going through this trouble over and over again.
What is the problem? Do you have the vacuum modulator installed properly? What type of transmission fluid are you using? Do you have transmission cooler? And is it installed properly? Was the converter inspected before you re-installed it? There are many cars out there making more power than your car that have the FLT/FLP transmission without any problems.
Sometimes parts fail.
Sometimes it's installation/programming error.
Sometimes it's customer abuse.
you really shouldn't be killing your trans with your set up as often as you do....heat is probably the main reason....try another trans builder, royal purple tranny fluid, and a BIG cooler....make sure the tune is appropriate for the trans (shifting, etc).
sdb
sdb
sdb
sdb
Something must be wrong with your setup there are alot of car with stroker motor setups running FLP/FLT 4L60Es in them without problems for years. Have you called and talked to Chuck is there a common problem with your failures?
Originally Posted by SHOPDOG
It's funny how you say 4 in 4 years when I do a search on your treads you've had more issues with that stroker overheating and what not. Oil in the antifreeze, overheating, manual down shifting, racing from a roll....I could go on all day. These are all things that effect the life of a trans. I found this while doing a quick search...https://ls1tech.com/forums/automatic-transmission/175561-flp-serious-customer-service.html. Man sounds like Chuck has gone way out of his way for a customer like you. Most trans companies would just laugh at you after reading your posts and wouldn't touch a trans for you. I wouldn't blame them. I do believe FLT builds a great product and you on here isn't helping your cause.
It's funny how you say 4 in 4 years when I do a search on your treads you've had more issues with that stroker overheating and what not. Oil in the antifreeze, overheating, manual down shifting, racing from a roll....I could go on all day. These are all things that effect the life of a trans. I found this while doing a quick search...https://ls1tech.com/forums/showthread.php?t=175561. Man sounds like Chuck has gone way out of his way for a customer like you. Most trans companies would just laugh at you after reading your posts and wouldn't touch a trans for you. I wouldn't blame them. I do believe FLT builds a great product and you on here isn't helping your cause.
All of them did this at some point. But accelerating forward would be ok from a stop. Also, all of them lost manual downshifting after awhile too.
I have a tranny cooler. 16,000 or 19,000, can't remember. Fluid, whatever was put in at Norris Motorsports. Its been full since day one. The converter was sent back to PI for a restall, so it was brand new.
sdb
sdb
Restricted User
Quickin...you do know roll racing, can be more severe punishment on your trans right? Like, your cruisin at 40, punch it, when it downshifts, it shocks the internals very very hard, which not many OD transmissions like, Ford or GM. Also, in MHO, that cooler is too small for your trans, unless you know what the temp is cruisin and under WOT (as you normally drive it and Roll Race it) I would opt for a larger cooler. Do you manually upshift as well as down? From my experience, manual shifting the 60E is going to accellerate its puking.
