Yes Another Gear Question
Wow, with that "duh" attitude no one is going to offer advice to a little smart ***...
The stall will drop .5 to 1 second off your ET, gears will drop .2-.3 seconds off your ET. You do not need a stall to do gears. A stall should be your first mod. This forum has a search feature.
Lol, it's ok. I really didn't know what you meant, you'd be surprised how mechanically uneducated some people can be.
You definitely should do a stall first. To me, an auto is nothing without a good converter. Gears are good, but they're not as important as a stall.
Gears Are A Good Mod By Them Selves But Will Complement A Stall Onverter By Makeing It More Streetable.. In The End You'll Eventually End Up Doing Both So I Say If You Got The $$ Just Do Em Both Now
For Most People A 3800 Stall And 3.73's Is The Way To Go .. If Its A Daily Driver Mabye A 3500... Also I Perfer To Keep The Str Down A Bit Since With A High Str Youll Blow The Tires Off Anything But Slicks So If Running Anything Less Sticky Than A Nitto I Would Say Stick With A 2.2 Str .. I Can Tell You I Have A2.5 Str And Will Destroy A Set Of 315-35-17 Nittos My Buddys 3500 2.2 Str Is Much Better Matched For That Tire Also If One Day You Are Gonna Go Big Cam Them Mabye A 4000 Stall Might Be In Mind .. Whatever You Do Make Sure To Consider Your Future Mods When Picking A Stall As Far As Gears Go Some People Go As High A 4.11 But I Wouldent Exceed 3.73 On A Daily Driven Car
