Converter + ????
Old 07-13-2006, 05:19 PM
RiPPinZ11's Avatar
Default Converter + ????
I'm looking into converters to liven up the car. 3500 stall probably. I have the stock 2.73s in it and dull exhaust, thats it. Would it be smart to get a flewplate or shift kit put in while its in the shop?? anything else im missing? thanks
Old 07-14-2006, 08:36 PM
Gold Z's Avatar
Just get the converter for now. You are right on with your stall speed selection. You won't need a new flexplate. The performance increase will amaze you. Later if you feel you need a shift kit they are installed with the transmission still in the car so removing the tranny won't be need to be done again.
Old 07-14-2006, 08:40 PM
HD1911's Avatar
if you are thinking 3500...then that really means you want a 4,000. Trust me, you will get bored with it and wish you had a 4000 + converter. I am bored with my 3600 already The converter is also gonna soften up your shift feel. Definetly would not be a bad idea to go Transgo right off the bat. Good luck man
Old 07-14-2006, 09:40 PM
RiPPinZ11's Avatar
Yea, thanks a lot for the input. Im gonna be thinking about the transgo shift kit. From what i read it should be a simple yes or no answer if i ask a trans shop if they install transgo shift kit.
Old 07-14-2006, 09:56 PM
Honda Hunter's Avatar
This man knows. I would go with some 300 rpm's higher than your initial choice.
Old 07-14-2006, 11:39 PM
Z28LS1camaroguy's Avatar
Dont get a trans shift kit those are crap, get a tune once you get the stall in and get your shift points set by the tuner, might aswell do gears while its getting tuned also. Im getting a 4400 fuddle stall with 3.73s from my crappy 2.73s and my car has already been tuned and can smoke tires with these crappy gears already so i cant imgaine what it will do with a stall and 3.73s.
Old 07-15-2006, 12:39 AM
RiPPinZ11's Avatar
let me no how that works out (the 3.73s). if u havent seen any of my other threads i start, i always wonder if 3.73s in a 2 series carrier is worth it. i hear a lot of bad things. actually i hear mostly bad things about those thick gears and whining and all that. any words of wisdom u can throw me to help me feel a little better bout that?
i really want 3.73s but i dont wanna risk it. thanks man
Old 07-15-2006, 01:28 AM
it depends on the gears you get, motive seems to be the best next to GM gears. Richmond i hear wine alot, as long as you have the gears set up right and get the whole kit then you will be fine. If you also want you could buy a three series carrier to put in it.
Old 07-15-2006, 01:34 AM
RiPPinZ11's Avatar
For now and after reading a LOT of threads, i like the 2.72s. If im gonna upgrade gears im just gonna save up my pennies for a 12 bolt. Im sure that wont be for a while tho. In the mean time, i want my 10 bolt to last so i dont even wanna take a chance.
Old 07-15-2006, 02:42 AM
98hardtopZ's Avatar
4k stall minimum...im kinda set on 3.23's, im a series 2 guy myself
