Torque converter bolts
Old 08-19-2006, 09:14 PM
1320ft's Avatar
Default Torque converter bolts
This may be a stupid question, but do you get to the torque converter bolts by taking the starter out and go through that hole? This is on a 98 TA (LS1). Thanks for any help!
Old 08-19-2006, 09:19 PM
zspot98's Avatar
Yes you do. There should be 3 13mm or 15mm bolts if I can remember right.
Old 08-19-2006, 09:29 PM
1320ft's Avatar
cool thanks
Old 08-19-2006, 10:29 PM
gillbot's Avatar
they are 15mm but I have seen some round ones on a few cars that need to be removed with a hex key socket.
Old 08-20-2006, 12:37 AM
1999Z28's Avatar
some are the 8mm hex ones. use a name brand tool, otherwise it'll round them out. If you want to make the job easier, you should probably get a torch to heat them up, otherwise even an impact will not break them loose in some cases.
Old 08-20-2006, 12:50 PM
jmm98LS1's Avatar
The 98's for sure have the 8mm hex bolts, mine did anyway. I also had to hit them with a torch for 30 secs and then hit it with a 600ft lb impact.....those f*ckers were on there good!!!!
Old 08-20-2006, 02:14 PM
Cap'n Pete's Avatar
The bolts on my '02 were a 15mm bolt, with the hex in the middle! But yeah, even on my '02 (not that old really) the bolts were in there pretty tight!
Old 08-20-2006, 06:06 PM
spy2520's Avatar
i dont know hoe you guys managed to get an impact gun in there, two of mine came out easy, the third had to be cut out because i rounded it...
Old 08-20-2006, 09:47 PM
1999Z28's Avatar
you can take out the starter(obviously) then get an extension over the k member and have you impact on the other side of it.
Old 08-20-2006, 10:10 PM
spy2520's Avatar
ah...i tried that with an extension and a ratchet to get more room but by then the bolt was already fucked up...
