yank ss 3600 and ms4 cam?
if your only planning on sprayin a 100 shot and its a weekend worrier i would get a pt4000 and it will kill anyone from a 15 roll...theres a new one for sale in the "for sale" section..
hey im getting the same setup but i will be spraying 150shot but that cams powerband starts at 2300RPM and ends at 6500rpm so i would think a 4000 would be a lil too much i would look into like a 3600 like you said so it will be tight and it should work with that cam like they were made to be together. just my .02 sense
The 3600 is a little low. I have a 3600 multi disc with lock up and a MS3. If you are going to drag race a lot I would go with 4000 or higher. With cams like the MS3 and 4 peak torque is made around 4500 rpm. or higher. You want to launch at peak torque. My car could use more stall, even on the spray. It leaves ok foot breaking it 1.54's, but off the trans brake it bogs. Don't worry about driving it on the street with a high stall when it locks up on the hiway you won't even notice it. The MS4 will need a big converter to tame it. Good luck
