best 4l60e mod
Old 09-28-2006, 03:05 PM
02 BLK WS6's Avatar
Default best 4l60e mod
I have been having problems with the 2-3 shift hitting the rev limiter. I replaced the stock servos with a billet set to see if it would have any effect. I am amazed at how crisp the shifts are now. I have tested it on the street and am eagerly awaiting to see if I can make a full pass on the bottle at the track without any problems. So far, so good.
Old 09-29-2006, 03:49 PM
usd2sing's Avatar
can u describe install?
difficulty rating 1-10?
or is it simple plug and play?
thanks.
btw. thanks for the response on the other thread
Old 09-29-2006, 04:00 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
HMMM,.I wanna hear about this!
Old 09-29-2006, 05:57 PM
s346k's Avatar
the best mod for the 4l60e is to remove it.
Old 09-29-2006, 06:05 PM
todddchi's Avatar
Check your sig?
Old 09-29-2006, 06:43 PM
s346k's Avatar
Originally Posted by todddchi
Check your sig?
"a4" does not mean 4l60e, as there are many other automatic transmissions with 4 forward gears.
Old 09-29-2006, 06:59 PM
02 BLK WS6's Avatar
The install was tight as I had to unbolt the cross member and let the tranny droop on it's own. I then still had to gently pry the tranny away from the tunnel. As far as ease goes... if you can do a tune up then you can install the billet servos. My experience so far has exceeded my expectations. Keep an eye on my sig next week to see if I net any improvements at the track. I'm looking to go better than an 11.5 in the 1/4 mile. The best in my sig was having to let off 2 or 3 times to get it to shift into 3rd.
Old 09-29-2006, 07:02 PM
02 BLK WS6's Avatar
thanks.
This isn't the name brand that I used but is almost exactly the same as what I used. This give a pretty good detail of the installation.
http://www.jetchip.com/pdf/howto/che...L60Eservos.pdf
Old 09-29-2006, 07:58 PM
usd2sing's Avatar
thank nathan...man o man i hope this fixes your problems....
keep me post,
thanks,
dan
Old 10-07-2006, 11:32 AM
usd2sing's Avatar
any updates?
the trans in the camaro needs a fix...IMMEDIATELY.
i did a test:
not stalling up the verter, leaving off idle the 2-3 shift was tight, crisp. (like what i want)
but if i load the verter and stall it up and launch the 2-3 hit is WEAK! lags....frustrating. UGH!
97blkz's Avatar
So untrue! I guess my 10's were magical?
Old 10-07-2006, 12:15 PM
staringback05's Avatar
id take the 4l60 over the shitty borg warner anyday
Old 10-07-2006, 02:06 PM
LS1Tech Sponsor
performabuilt's Avatar
The billet servo is fine and we use them in our level 2 and 3 unit however be warned that the stock band pin area cannot stand the force vey long and will tear through after a bit resulting in loss of 2nd and 4th , We do not suggest the use of the billet servo either sonax or superior with the stock band ,
www.performabuiltautomatics.com
Old 10-07-2006, 02:51 PM
02 BLK WS6's Avatar
I went to the track Tues. Made a motor pass and shifted fine. No hitting rev limiter. 2nd pass turned on the bottle=hanging in 2nd still and hit the limiter. I am now looking for a complete core as cheap as possible, locally so I can build it. My tranny builder is going to teach me how to build a 4l60e.
Old 10-07-2006, 03:38 PM
usd2sing's Avatar
thats what i needed to know.
thanks nathan.
Old 10-07-2006, 04:09 PM
s346k's Avatar
this is your 6th 4l60e, nice going. for every ONE guy running good power successfully with a 4l60e, there are 15 that are on their 2nd or 3rd "built" 4l60e still bitching that it slips or is broken.
Old 10-07-2006, 04:33 PM
LS1Tech Administrator
RPM WS6's Avatar
Received 1,493 Likes on 1,075 Posts
Yeah, that's probably because the other 15 guys went to the wrong builder.
A 4L60E trans + some time at FLT = an excellent 4-speed auto trans.
Old 10-07-2006, 10:09 PM
SPRAYED 01's Avatar
Just got back from the track with the m6-a4 conversion. Mine bounced off the rev limiter everytime from 2-3. This is a built dr-evil stage 3 trans. Other than that it felt perfect. What could be the issue?
Old 10-07-2006, 10:38 PM
RPM WS6's Avatar
The Question:
Originally Posted by SPRAYED 01
Mine bounced off the rev limiter everytime from 2-3.........What could be the issue?
The Problem:
The Answer:
www.finishlinetrans.com
Any questions?
Old 10-07-2006, 11:07 PM
SPRAYED 01's Avatar
All in time my friend. But for now i need some good times out of the dr.evil. I am really confident the issue is not with the trans. Ill take you for a spin in it when i see you next. I believe its in the tune. Its going back to FLP on the 14th.
Quick Reply: best 4l60e mod
