Converter to Flywheel Picture Inside. Look.
Old 11-12-2006, 06:23 PM
hashtagBMW
Speed Density's Avatar
Default Converter to Flywheel Picture Inside. Look.
Okey i got the trans up and everything is coming together.
The converter looks kinda far from the flywheel, but thats just me.
Is there something i should do or change?
Ill have more pics, the others didnt upload.
Tony.
Old 11-12-2006, 06:43 PM
hashtagBMW
Old 11-12-2006, 06:50 PM
UnitZ28's Avatar
you just push it together and bolt it up
Old 11-12-2006, 07:03 PM
FLT
FLT's Avatar
Use a 3/16 drill bit as a gauge between the tc and flywheel. If it is more than that I would use a washer between the flywheel and tc.
Old 11-12-2006, 07:04 PM
Moderator
JNorris's Avatar
How much of a gap is that, 1/2 inch?
Old 11-12-2006, 07:17 PM
hashtagBMW
1/2 in or a little less.
So its okey if i just use washers?
Tony.
Old 11-12-2006, 07:21 PM
FLT
FLT's Avatar
I have been shimming tc's for a long time. I would make sure that the washers are equal thickness. You might want to check with the tc company so there is not a warrenty issue. But if you leave too much of a gap in there you could have a pump failure issue.
Old 11-12-2006, 07:24 PM
BlackHawk T/A's Avatar
There is no flywheel on an automatic car!
hashtagBMW
To much of a gap between the Flywheel and converter?
Tony.
Old 11-12-2006, 10:23 PM
hashtagBMW
Bump.
Going to try and finish this project when i get off work tonight.
Tony.
