Need a big trans cooler, what is the biggest....
tried searching but couldnt really find anything. My car isnt going back on the road til may but I know that I am going to need a bigger trans cooler. i currently have a 24,000 gvw but would like to upgrade once and make sure its gonna be enough to daily drive, remember, its a nonlock up converter..... what is the biggest and best cooler I can go with....
You could add a second cooler on the other side of the radiator or add a rail mount cooler on the undercarriage. I wouldn't hesitate in getting a finned deep pan either. I have the TCI (holds two extra quarts).
all you will need is the B&M 24000gvm and you will be fine
Originally Posted by Stuarta
I have used them many times.
The bone yards are full of them.
Clean it out well and bolt it in.
I use two B&M 24Ks. I pretty much removed all the baffles and the washer reservoir from in front of the condensor (bought and relocated the bottle), and hung both 24Ks off the top of the bumper bar, facing the condensor. I have them at a slight angle to help catch some of the airflow on it's way from the deflector, to the condensor/radiator.
My stall isn't as big as yours, but, in the summertime, in traffic, when the converter doesn't lock-up much, stop-and-go, my temps' don't get much past 180*, while it's 100*+ outside. This is in a 45 minute commute, at low speed. My brother, with the same converter, has the same set-up, minus one 24K cooler, and he will get up to 200s pretty quick, any time.
The two are overkill, this time of year, with regular daytime temperatures in the 60s, but, it's easier to block a little airflow, that it is to make it cooler. So far, after two years of this arrangement, I don't see any moisture or milky colored tranny fluid, like it's not getting warm enough to burn out moisture, so, it seems to work for me.
Originally Posted by nodnarb481
im gonna watch this thread because I am getting a 2800 and i dont know what cooler to get either...
BTW, I used to live in Collegeville.
Originally Posted by BA98TA
Do you have a DIY write up on this? Its an interesting idea...
I pour solvent into the condensor and shake the bejesus out of it.
Then blow it out with my air compressor.
Both ways, several times.
Then just bolt it in and hook up the lines.
Hi guys!
Im using the original converter but already broke 4 tranys (4L60E) using just a little bit more than normal, But I really didnt find why, well, it has to be for temp, so I bought to Aless, his trany which are never open, just with deep pan oil and Trans Go Stage 3 and I already bought B&M´s Supercooler from 13,000btu´s (70268).
His SS Camaro used to run 11´s but so I decide to buy a Trany used that way but sure of work like it has to.
He are telling me that install other Supercooler like he was, but all the people told me that doesn´t necessary, BUT I REALLY dont want to broke again the trany.
Do you guys thing that is a good option?, or it is better just install a bigger Supercooler?
Like I said, Right know my Z28 98 Ls1, with 49K miles on it has no modifications, just little mods, stock converter, 3.23 rear gear (3.73 on the way), 1 Supercooler, Deep oil pan on transmission with ventilation.
Thanks for your help
www.camaro-transam.com (RogerZ28)
