Will i be ok with 3500 stall through the winter with no cooler??
Im having my tranny rebuilt as we speak and i was wondering will it be ok to drive my car without the cooler now that it is winter and cold? i have a B&M 24000gvm cooler new in the box but hasn't been installed yet.
i didnt have one with a built tranny and a 3500 and i burnt up the 3/4 clutch after the cooler i have had noooo problems ... goo with b&M. not those shitty tublur ones you can buy at autozone thers no difrence between those and your stock cooler..
http://www.prostreetonline.com/buy/b...ssion_coolers/
or a similar cooler to that one.
dude, the cooler is about $100, and the install is less then an hour, $40 labor, just get it done. It's safety for something that could end up costing you thousands later for a tranny rebuild.
If you've allready got it. Why not install it when you do the converter? Theres no hard work envolved.
BTW- did you get those LTFT's in line?
Would it be redundant to say "PUT THE DANG THING IN, ALREADY" ?
Look at it this way:
Yes, you might be O.K. But you may also either burn it up, or do damage that will affect it later. Since it costs +1500 to repair/replace the trans, it is "illogical" not to install it now.
Best of luck with your decision, kk
Originally Posted by nodnarb481
what cooler would you recomend for a 2800 in an lt1?
im not trying to jack this thread sorry...
you guys must have serious inadequate stock cooling. I'm using the stock coolers that came on my car (so I added an additional quart of fluid by adding some line and an external filter) and I've never seen temps above 200 degrees even with hot lapping on 100degree days
