4l60e WHAT THE!!!
4l60e WHAT THE!!!
i have taken off everything all 9 bolts out of the transmission driveshaft crossmember you name it bolts from flywheel/convertor and it acts like the transmission is welded to the motor? any ideas?
GM heat valve lubricant on the dowel pins. Either that or use some PB blaster and let it sit overnight. I sometimes have to use a pry bar to wiggle the trans to get them loose.
i've found that the best is take the plastic cover loose(one 10 mm socket) on the drivers side loose and get a big pry bar in there, seems to be the best place to pry. Its probably just stuck like everyone else said.
