4L60E Under 20 degrees = no 2-3 shift?
Old 12-04-2006, 11:02 AM
sawzall wielding director
G-Body's Avatar
Default 4L60E Under 20 degrees = no 2-3 shift?
Sometimes when it is under 20 degrees and my car is cold it will not shift from 2-3. It shifts from 1-2 just fine, but then will not shift into 3rd. This has happened about 4-5 times in the last two winters, it only happens when it is cold and the car has been sitting for at least 12 hours. Today it is 18 degrees and it took almost 2 miles to warm up enough to shift into 3rd, the other 3-4 times that this happened it took less than 4 blocks to shift into 3rd.
What is happening? Is this a common problem? What should I be doing letting the car sit and warm up? Or is driving it ok?
The trans has been doing that since I put the car together last august. The trans filter and fluid were changed when I put the car together, when I changed it the fluid was still red and there were no particles in the pan. I have since changed the fluid and filter again and the fluid was bright red, clean, and no particles.
Old 12-04-2006, 12:26 PM
brady346's Avatar
Mine goes into third and fourth fine but wont lock up under really cold conditions. Im interested in this thread also.
Old 12-04-2006, 12:42 PM
mattraypharbor's Avatar
theres a temp that ur tranny is set to lock up at its ither 95degrees or 195 im thinkin 195
Old 12-04-2006, 01:09 PM
LS1Tech Sponsor
performabuilt's Avatar
Lock up cant occur generally unless the trans is over 130 degrees i have seen this vary and little but thats most cars ,
On the third shift problem I would guess sticking valve in valve body , when cold
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 12-04-2006, 08:21 PM
nikon1999's Avatar
yeah..extreme cold weather like that makes all my vehicles cranky
Old 12-04-2006, 09:09 PM
camaro98z28's Avatar
I was in Wisconsin this past week and it seemed nothing wanted to work on any Vehicle. LOL
Old 12-04-2006, 09:12 PM
G-Body's Avatar
Would it be more likely that the electronic shift solenoids are sticking and bad, or an accumulation of sludgein the valve body is stopping them from moving?
Old 12-04-2006, 09:47 PM
LS1Tech Sponsor
sludge is possible and a solenod but a solenoid would likley set a code
__________________
Call 888-744-6542
Old 12-04-2006, 09:49 PM
Gilbert@Ace Racing's Avatar
Well the answer is subjective. It can only be opinion based until diagnosed. The valves may stick because they are simply stuck until they warm up. The 2-3 shift solenoid could be sticking as well. Based on you previous comments about the fluid condition it is not likely to have significant "sludge" build up on the valve assy. Another answer could be that the 3-4 clutch apply piston seals are worn and are bypassing hydraulic pressure until they warm up.
My opinion is the rubber seals are aged and are bypassing pressure.
g
Old 12-04-2006, 10:50 PM
G-Body's Avatar
I know that everything is just a guess till the trans is apart.
I just wanted to get an idea of what was more likely to see if I wanted to pull it apart now or wait for warmer weather. (I don`t have a garage now, and the driveway is really cold this time of year )
Old 12-04-2006, 11:20 PM
LS1Tech Sponsor
All the above are possibilites but one way to determine cause would be to scan in each case and see if the command to shift was given
__________________
Call 888-744-6542
Old 12-05-2006, 12:16 AM
Tech Resident
ChocoTaco369's Avatar
well, i'm not sure how i feel about this one, but i'll post it anyway.
seafoam makes a product called seafoam trans tune.
http://www.seafoamsales.com/transTuneConsumer.htm
if your problem is due to sludge buildup or something sticking due to sludge, this could possibly help. i don't know how comfortable you are pouring a foreign substance into a tranny, particularly a 4L60E. honestly, i'm not 100% comfortable myself. just if this is a big problem for you, you may want to consider it.
i mean the product IS made my seafoam. their engine treatment stuff works wonders, so i imagine their trans stuff is good, too. it'll perform a transmission flush, so i imagine if you use this stuff, you'll have to change your fluid pretty quickly afterwards. at least consider it. it may help.
