what is wrong with my A4?
Today I punched it in my 94 z 28 a second after it shifted into second. The tranny downshifted normally and it pulled through first fine, but instead of hitting second, it bounced of the rev limiter a few times and would not upshift until I let off. The car does seem to hesitate a little on the 1-2 shift, but it had never hit the rev limiter before. I didnt even think an a4 was able to hit the rev limiter in drive. For the most part, the car shifts fine under acceleration, so i dont think it needs to be rebuilt (knocking on wood) . If you have an idea of what might be wrong or a link to a similar thread that I might have missed on search, I would appreciate if you would let me know.
Originally Posted by Vince @ FLT
You could be having band begining to fail or maybe even a broken 1-2 accumulator or broken accumulator spring. Does your car have a stall?
Originally Posted by PBA
Has the 1-2 part throttle shift changed? or just the WOT shift? Is the shift getting longer, sliding into 2nd gear?
