pilot spacer/ 350 turbo converter to ls1
LS1Tech Sponsor
The converter is not made to be supported by the flex plate you will get vibration,eventual flex plate failure and possible pump damage the back of the crank is the support and center for the converter the flex plate does just that flexes and will not stay true .
__________________
LS1Tech Sponsor
Not to sure about that either since the trans depends on the dowel pins for supports , Alot of people think the bolts are what keep it from twisting on the block but in reality all they do is hold it against the block , The dowel pins keep it centered and from twisting
__________________
Originally Posted by Darracq
Anyone run without one. What is the purpose off the pilot to go into the back of the crank, if the converter is help tight on the flexplate what would it hurt?
here is the info you need
no need to buy an expensive converter
https://ls1tech.com/forums/automatic-transmission/639693-ls1-style-engines-old-style-trans-th350-400-2004r-700r4-4l60e.html
Any idea why my converter is binding in the gm spacer? i have to use a washer between trans and block and it will work, I am prettty sure my converter is all the way in.
i have heard that some people that use the gm spacer on the front side of the flex plate sometimes need to mill about .100" off the spacer, i have not ran into this issue
what flex plate are you using?
