overfilled tranny by about 1/2 qt. okay?
Well I just had my new tranny/stall put in, and they said when I got home to check it running/warmed up. I checked it, and it was about 1/4" below the cold reading which is below the hot reading. anyway, I put about 3/4 qt. in it now it is about 1/4" above the hot reading. is that allright, or will I have to drain some, not sure how, don't have a drain plug on it. anyways just curious...thanks..
performa...will overfilling hurt the tranny? when I remove my dipstick tube a little pours out.
im placing a new tube in it today and need to know if i need to drain some fluid out.
My car developed a small drip and was told by a tranny shop that the 3200 stall could be causing the drip because the fluid level is to high. So it could be pushing it out the overflow. We checked the level and it is at full or a shade above the cross hatch. Usually drips more after a day at the track or WOT spirted driving. So I was told to take some fluid out.
i have the same problem just put a new stall in and i think i overfilled it now it drips like a SOB!! and all the lines are tight !! should i just keep driving it and check the fluid levels frequentlY?
What would be wrong with running an aftermarket fluid cooler (or duals like I have) then after the fluid leaves the cooler, the fluid then goes into a tank that holds - say 2 quarts of tranny fluid........then it returns to the tranny?
Since you mentioned (in another thread I started) that line pressure will not be effected as long as the fluid level is full in the tranny pan.........wouldn't this idea effectively make the system 2 quarts larger?
Or maybe a tank that holds 3 ,4 ,5 quarts...........???? A elongated tank could be mounted behind the air dam on the frame.
Just a thought......my mind is always thinking of stuff......
The extra capacity will only to serve as just that.... a reservoir for the fluid. It will serve no other purpose than to maybe store cooled fluid, which could potentially interrupt the lubrication circuit pressure and volume. When the fluid returns from the cooler it is send directly to the lube circuits for the rotating assembly, then returns to the pan.
Besides, the whole idea of adding up to an extra qt of fluid to a 60e is to provide sufficient volume in the pan during WOT events. In a properly filled (factory marks on the dipstick) unit inertia can and will cause the filter to cavitate on hard acceleration.
Hope that helps...
g
Hope that helps...
g
If it is overfilled by too much then yes it will set it's own level, meaning eventually it will stop leaking. But it's going to make one helluva mess under the car if that's the case.
The only place it can leak out if it's overfilled is the vent hose which is located at the top of the case. It sits at 12 o'clock right behind the bell housing. It should have a rubber hose on it that extends back a foot or so... check to see if that's where the fluid is coming from.
g
Hope that helps...
g
Hope that helps...
g
And, from what you're saying, if we cool the fluid too much before it gets returned to the tranny pan........is BAD?????
So, after the fluid goes through my coolers and heads back to the tranny....is it the pan that the fluid gets dumped into, and then gets picked up by the pickup tube to go to the lube circuits and rotating assembly?
It is hard to over-cool trans fluid, and in any case is not a bad thing...
160F is probably the ideal temp for trans fluid.
No... the cooler return fluid passes thru the TCC valve and directly feeds the lube circuit which feeds the bearings for the rotating components and splashes the gearsets (i.e. the bearings/gearsets receive cooled fluid)... and only then after that it falls into the pan.
It is hard to over-cool trans fluid, and it any case is not a bad thing.
Another question: How powerful is the pump...meaning how much fluid can it push though lines, coolers and possibly another tank that holds 2-3 quarts of fluid???
I was thinking if it will not lose line pressure or cause any issues...or get overworked.......putting a long thin tank behind the air dam that will mount perfectly and hold about 2-3 quarts more fluid. I would let the fluid go to that tank AFTER it traveled through my dual coolers.
Overkill?????
The cooled fluid that is fed into the lube circuit has to not only lube the bearings/gearsets, but it also has to remove heat... cooler fluid can remove heat much more efficiently than warmer fluid.
